Use the normal i/p from the triwatt How hi power did you want to go to? I use my Triwatt as my bass amp on a regular basis so there should be very little tweaking needed. So it would be finding the iron for the output, probably hammond. Use 2 - 4 o/p tubes per side, efficient speakers and you can boom with the best. This should give a front pnl with i/p level, bass, treble, mid can be either preset or pot control. Master volume would be up to you, I would put in a switch that would bypass the tone stack. Not sure if VRM would be a good thing or not, but worth looking into.
_________________ Fantasy Noise is what my shop of dreams is called and was the only way to beat my addiction, like many here I suffer from G.A.S.
Tele's make the best noise
