It is currently Sat Dec 13, 2025 11:53 pm
PostPosted: Wed Aug 11, 2010 4:20 pm
Hi,
I've been using my plexi for about a year with no problems.
I finished another amp and haven't used it for about a month, switched it on and i've got normal
channel sound but i don't think it sounds quite right and no sound in the other.
What would cause this and how do i fault find the problem.
Thanks.
PostPosted: Thu Aug 12, 2010 5:38 pm
Suspect tubes first. Change a few if you can. OR / then measure voltages and see how they comapre to your original build & resource section postings. Also, confirm cables is good , etc, etc.
PostPosted: Fri Oct 01, 2010 6:28 pm
Bloody hell it was a different tube in v1.
Swapped it with another one all is well.
I need to deal with squeal now.
Good advice though.
Thanks.
