It is currently Tue Jan 20, 2026 12:19 pm
 Post subject: Octave-Up with Overdrive
PostPosted: Fri Sep 16, 2011 7:00 pm
Hello, all! I recently completed a Triwatt build. While I love the clean tone on this amp, especially with KT66's(!), the overdrive only sounds good about halfway up. Beyond that I start to experience some weird octave-up effect like a fuzz pedal. Was hoping someone would have some suggestions for me to fix this. Here are some pics. I know they are not the best and I can attempt to take more if that would be helpful.
PostPosted: Fri Sep 16, 2011 7:04 pm
More Pics:
PostPosted: Sun Sep 18, 2011 1:06 pm
Anybody?
PostPosted: Sun Sep 18, 2011 4:26 pm
Cant say I've ever heard this but try placing the coax to the OD switch Above the board, not below it.
PostPosted: Sun Sep 18, 2011 6:13 pm
Thanks! I'll give that a try.
PostPosted: Sun Sep 18, 2011 9:10 pm
Maybe shorten up some of the leads around that tube as well.
PostPosted: Mon Sep 19, 2011 8:12 pm
Also a number of the solder joints on the turrets look suspect to me.
PostPosted: Fri Sep 23, 2011 11:13 am
So I reflowed most of the turrets and moved around some wires all to no effect. Replaced V2 with other tubes without effect. Finally I decided to put a 12AX7 in the PI position instead of the 12AT7 I had in there so I wouldn't have to drive the preamp so hard to get good distortion. Now it's all good. Don't have to turn the overdrive past 2 o'clock to get pretty saturated distortion, but I still have plenty of clean headroom, too.
PostPosted: Sat Sep 24, 2011 7:51 pm
Good news. Possibly the AT7 was suspect though. But as long as you like the result, that's the objective.
PostPosted: Sat Sep 24, 2011 9:23 pm
While I'm at it, can anyone explain why the pre-PI MV on this amps works so well? Although the amp sounds best when cranked, it sounds pretty convincing at lower settings on the MV as well.
