It is currently Sun Jan 25, 2026 8:42 pm
 Post subject: PT question
PostPosted: Mon Sep 19, 2011 1:47 pm
I have a MM power tranny that is 315 watts, vs the 290 specified on the Trinity layout - would there be any issues due to the higher voltage?
I ask because I recently fried an OT and I am investigating all possible causes for the problem - I would have thought the voltage would be OK as MM sells these as 18 watt power trannies
I think the OT issue was likely related to a poorly soldered speaker jack and the OT getting zapped due to no speaker load (I found the poor jack connection when I tried to run another amp on the cab and it did not work either - at least I did not fry the other amp too).
Question # 2 - I have read about running a big resistor on the output jacks to prevent a no speaker OT failure
What value resistor would you use for the 18 watt OT if I want to do this? I have seen several values on the net for various amps but read it kind of depends on the OT.
Any issues using a resistor in this fashion?
 Post subject: Re: PT question
PostPosted: Mon Sep 19, 2011 10:45 pm
My Trinity PT puts out 311VAC instead of the 290v. Mine seems to be running fine so far. Not sure about the resistor on the output.
Les
PostPosted: Tue Sep 20, 2011 7:30 pm
290 Volts AC is is nominal under load. Mains voltage will vary changing the output voltage. 315 is a bit too hi for my liking but there are ways to drop the B+ with zener diodes.
20 watt 10 ohm resistor on a switched output jack would be fine.
