It is currently Wed Apr 08, 2026 3:17 am
Post new topic Reply to topic  [ 132 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Wed Nov 23, 2011 4:54 pm
Those voltages look normal and the pop is fine.
Probably have a signal wiring somewhere. Check all the pots and switches.
PostPosted: Wed Nov 23, 2011 5:23 pm
Ah, i knew this would happen.. I'm missing the connection from lug 3 of the Volume pot. fingers crossed this is the only thing wrong :)
PostPosted: Wed Nov 23, 2011 5:34 pm
ok, added that wire. still no sound... gonna recheck wiring again.
PostPosted: Wed Nov 23, 2011 5:56 pm
The wire from the 2nd lug of the master volume to the power tube should be shielded right? It doesn't show it in the layout but its in the instructions. I have the shield grounded at lug 1 of the master volume. Is this correct?
PostPosted: Wed Nov 23, 2011 6:36 pm
This is the volume pot or gain pot( on schematic). The Master is the pot feeding the output tube. But yes Lug 1 of the volume pot is grounded and the shield is connected there too. The Master also has pin 1 grounded but at a different point in the circuit. I wouldn't think it neccesary for shielded wire at the Master volume location.
Stew
PostPosted: Wed Nov 23, 2011 6:55 pm
ok... in that case. I'm stumped. All the measurements are what they should be. and All the wiring looks right to my eyes unless I'm missing something really obvious... :hmmm:
I guess all I can do it go over the wiring again and again, and double check the bottom of the board... but if that was incorrect wouldn't that cause incorrect measurements?
PostPosted: Wed Nov 23, 2011 6:58 pm
Not if the problem is in the audio path. The voltages could all be fine.
Do you hear anything when you probe pin 7 of V1? ( probe with a meter lead or even a small screwdriver ect.)
stew
PostPosted: Wed Nov 23, 2011 7:06 pm
Just tried and got nothing.
PostPosted: Wed Nov 23, 2011 7:23 pm
How about pin 5 of the output tube. This spot is not as sensitive as the preamps so listen carefully.
PostPosted: Wed Nov 23, 2011 7:30 pm
I rechecked both spots... I got sound on both this time. I must have not heard it the first time.. so yeah. hum at both pins
PostPosted: Wed Nov 23, 2011 7:34 pm
Sorry if we've been here before but....pin 2 on V1? ( with all controls turned up).
PostPosted: Wed Nov 23, 2011 7:38 pm
no sound there. for sure this time
PostPosted: Wed Nov 23, 2011 7:43 pm
Then try pin 7. Then try pin 5 on the output tube.
PostPosted: Wed Nov 23, 2011 7:49 pm
Ok. Have a look at the schematic. You see the audio leaves pin 1 of V1 and is coupled to the gain pot via the coupling cap C2. It ends up on lug 3 of the volume (gain) pot VR1. It then leaves that pot on lug2, goes through R6 (330K) to the grid on Pin 7 .
Can you check that path backwards with your probe and see where the signal stops. Be carefull on the tube end of the coupling cap ...there's high voltage there!!!
PostPosted: Wed Nov 23, 2011 7:57 pm
I'm not getting anything at any of those points.. unless I'm doing something wrong :oops:
PostPosted: Wed Nov 23, 2011 8:00 pm
Ok.. we know there's a pop when you touch pin 7. So there's nothing at the other end of the 330K connected to pin 7 ?
PostPosted: Wed Nov 23, 2011 8:07 pm
no
PostPosted: Wed Nov 23, 2011 8:11 pm
When you prepped that shielded cable you didn't short the center conductor to the shield in some way? You didn't use the center lug on that connection strip next to the tube.? The volume pot doesn't have pins1 and 3 reverse wired?
PostPosted: Wed Nov 23, 2011 8:19 pm
no, no, and no.. Should I redo the shielded wire just in case? I believe I was careful to avoid shorts though.
PostPosted: Wed Nov 23, 2011 8:24 pm
Well you should get some sort of pop /hum/noise when probing both sides of that 330K resistor. Before ripping out that cable check that you don't get better results with the volume pot rotated the other way and the "tweed-tude" switch engaged.
