It is currently Tue Mar 31, 2026 5:09 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jan 23, 2012 9:42 pm
Can you believe some people get tired of seeing another tweed cabinet built
awful in red..
PostPosted: Fri Jan 27, 2012 5:19 pm
Whoa! Stupefying!! :thumbsup: :thumbsup: :thumbsup:
PostPosted: Sun Jan 29, 2012 4:31 pm
Thank you guys, I appreciate it :o
PostPosted: Thu Apr 26, 2012 5:30 pm
Joey,
I am inspired by your beautiful work.
Do you install and wire everything on that wooden board and then transfer it en mass into the chassis?
Scott
PostPosted: Thu Apr 26, 2012 5:48 pm
You would need to use bottom mount tube sockets, the rest should be fine.
PostPosted: Fri Apr 27, 2012 2:36 pm
Yes, but our sockets are top mounted. They would need to be widened a bit to fit. Or get bottom mounted.
PostPosted: Fri Apr 27, 2012 3:24 pm
I'll wire the tube sockets in place and maybe do the rest with a jig.
PostPosted: Fri Apr 27, 2012 5:22 pm
sorry guys I meant top mounted ! I anted to do the jig but found I didn't need to.I googled images
and followed those, there just aint that much wiring, save the trannys for last !
PostPosted: Sat Apr 28, 2012 2:07 am
joeyvelour wrote:
Thanks Stephen, no mods needed for this thing! I played it in my friend's studio for about 5 hours yesterday and I think I saw a tear running down his face when I loaded it back in my car :P I may have to build another one!!
who wouldn't want a special amp built by a special guy ... :) Wow, you're the greatest and probably just as great on the neck of a guitar too... :)
PostPosted: Sun Apr 29, 2012 4:05 pm
ScottMellor wrote:
Joey,
Scott
Thanks Scott :D
Everything I possibly can gets routed and soldered on the build fixture prior to ever seeing a chassis. The tube sockets do have to be bottom mounted. The sockets I'm using here can be top or bottom mounted, and fit the same panel cutout and dimensions as a standard chassis with no mods. Everything besides the transformers can be done in advance and folded into the chassis in one piece. I have a solution for prewiring the transformers as well, but it's not really worth it for those last few wires IMO, unless for some reason I wanted to test the amp on the jig first as well. Working on a fixture gives me way better control, I could make a thousand of these amps and they will all be identical, plus it saves my fingers for playing!! I used this same approach on my 18 watt as well...!
PostPosted: Mon Apr 30, 2012 9:53 am
Beautiful to look at.
A work of art.
