It is currently Tue Mar 10, 2026 3:35 am
PostPosted: Sat Jun 02, 2012 4:58 am
hello all
I have just completed my 5e3 build with no real problems.
what I would like to know, is a little about the tone and volume controls.
I understand the volumes are interactive
but two questions
A) do you have most of your clean volume by about 3-4 on the volume dials
B) when I turn up the tone control, it gets increasingly brighter up to 9 and then, from 9-12 the brightness tends to decrease.
are these two situations normal with the 5e3s
PostPosted: Sat Jun 02, 2012 10:55 am
A sounds right
B not so much. I'd check your wiring to the tone pot. I'd also check the pot itself to make sure it doesn't have a "dead spot" from 9 and above.
PostPosted: Sun Jun 03, 2012 9:25 am
Thanks Kurtlives
I will check it all out, it is still a great amp
