It is currently Wed Dec 03, 2025 10:19 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re:
PostPosted: Mon Jun 25, 2012 8:04 am
Fresh_Start wrote:
You could feed a Tweed Deluxe preamp into a Blackface power section - probably would be really cool (especially if you had a switch to jumper the two input triodes in parallel)...
What you're describing there is basically the Brown Deluxe, another classic from the early Fender amp days.
PostPosted: Tue Jul 03, 2012 11:26 am
If you want cleans, the mods we do to the PI & coupling caps will get you into that region , using a 5E3 Tweed circuit as a start. But you'd have to choose a single coupling cap value. We went with .022 and removed the PI 25uf bypass cap andadded a 470K PI smoothing resistor.
PostPosted: Mon Aug 20, 2012 11:57 pm
One added thing would be to get some NFB around the output, something like this to go from normal Tweed to clean.
