It is currently Tue Jan 20, 2026 8:26 am
 Post subject: Master volume
PostPosted: Tue Sep 04, 2012 12:29 pm
:?: I've had my Triwatt complete for a while now and I'm using it with my band as my #1. it sounds great and has performed flawlessly but.......
It's pretty loud. I've been using 6V6 tubes and now I'm trying some KT66's. If I am not using the OD channel I can push the volumes and use the master to get a nice level but if I engage the OD (which I love) the master volume has a very limited useful range (and it's at such a low setting that it's very touchy). Is there anything that can be done to make the master easier to use without affecting the normal channel?
 Post subject: Re: Master volume
PostPosted: Tue Sep 25, 2012 7:42 pm
So the Master Volume performs OK when in Normal mode, but his less effective in OD mode. Did I get that correct?
PostPosted: Wed Sep 26, 2012 10:03 am
Is your MV pot linear or audio taper? In some cases a linear MV pot can be touchy at the bottom of the range.
** b0b0 **
- This Space For Rent -
PostPosted: Wed Sep 26, 2012 10:11 am
Spec is for Audio - 250K-A
PostPosted: Fri Jan 09, 2015 9:45 am
I'm thinking in a similar preamp design, anyone tried to switch between two master pots to have a separate OD master with a DPDT relay?silly idea?
PostPosted: Fri Jan 09, 2015 7:35 pm
That's more or less what the OD control does.
Uses a switch to add another stage of active gain.
A more useful mod would to be adding another pot after the "od stage" to control the overall volume.
PostPosted: Sun Jan 11, 2015 5:17 pm
That's a good idea. A sort of mix control between clean & OD would be useful. Dumble like?
PostPosted: Sun Jan 11, 2015 10:37 pm
Exactly!
I always figured if I built a Triwatt I'd try that.
You could set the pre-volume (OD control) with a trim and have the pot on the panel control the overall volume.
You could also use a dual gang pot and change both at the same time. Might take a couple extra tapering/setting resistors but would be fun to experiment with.
