It is currently Thu Jan 29, 2026 8:01 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
PostPosted: Fri Nov 23, 2012 8:32 am
Hi,
Can someone share some plans for the 18w 2x12 combo?
I think its H20''xW28''xD9'' with a 16 1/2'' x 2 3/8'' cut out for the chassis.
I do not know the top grill cutout or the thickness of the ply. I read 13 layer ply, and also 1/2'' ply.
Can you guys please help me with the thickness, or post any plans for this?
João
PostPosted: Fri Nov 23, 2012 9:55 am
We'll send you a copy for your personal use.
PostPosted: Wed Jul 01, 2015 5:09 pm
I'm in the process of building one of these right now and would really like to build the 2 x 12 combo, could I have a copy of the plans too?
PostPosted: Wed Jul 01, 2015 10:39 pm
Which model kit do you have?
PostPosted: Wed Jul 01, 2015 10:49 pm
I'm scratch building the chassis, it's not a kit. I've been looking for cabinet plans for something to house it in, and ran across this thread via a Google images search. The chassis is some horrible Chinese thing that looks like it's intended to go into a a head cabinet (tubes on top of the chassis), but I'd really like to build it as a 2 x 12 combo. I have a full wood shop and would like to scratch build the cabinet too.
PostPosted: Tue Jul 07, 2015 5:47 pm
put something useful in the resource section
viewtopic.php?f=12&t=1249
PostPosted: Thu Jul 09, 2015 4:30 pm
Can some confirm that the difference between the 1X12 combo and a 2x12 combo is only 4 inches?
All other dimensions are the same.
PostPosted: Fri Jul 10, 2015 12:32 pm
28" wide is pretty standard for a 2x12. A 12" speaker is really less than 12" so there's plenty of room in 28" for two speakers, battons and your cabinet sides.
PostPosted: Sat Jul 11, 2015 3:05 pm
The cone is less than 12" but the basket is often 1/8"-1/4" more in my experience.
28" with 5/8" thick material etc. makes for a pretty tight fit. Be sure to measure it out.
PostPosted: Sat Jul 11, 2015 3:17 pm
Thanks for the update Stephen, I appreciate the update to the 1x12" plans!
PostPosted: Sun Jul 22, 2018 10:04 pm
SPAM!!
PostPosted: Wed Apr 03, 2019 11:55 am
I’m a few years late to this post! I am trying to do the same thing, so thanks for the helpful information. My problem is joining the corners. I have built previous cabinets with pine and used a dovetail jig and router successfully. But I am using birch plywood for this build, and even with a brand new router bit, the plywood chipped away badly when I tried to cut the tails. Any ideas? I was going to either try hand cut box joints, or resort to butt joints with some internal bracing.
PostPosted: Wed Apr 03, 2019 2:30 pm
Plywood and fancy joinery don't go well together. If you are using baltic birch plywood, box joints work, but they would be very time consuming to cut by hand. Also difficult to get a nice tight fit without using some kind of jig and either a table saw or a router.
I would just use but joints with internal bracing and lots of glue and screws.
PostPosted: Wed Apr 03, 2019 10:27 pm
Thanks, Mitch M!
PostPosted: Thu Apr 04, 2019 10:10 pm
We do use box joints with a jig. Suggest you use biscuit joints if you cant to the box joints. Fast, strong. We use on most of our head cabs now.
PostPosted: Mon Apr 08, 2019 1:48 am
Thanks, Stephen. I may buy a biscuit joiner tomorrow. What size biscuits do you use with a half inch plywood? Can you use the number 10? Or do you need to stick with #0? Thanks!
PostPosted: Mon Apr 08, 2019 10:03 am
I think we use #10
Users browsing this forum: Google [Bot] and 18 guests
