It is currently Tue Jan 20, 2026 8:32 pm
 Post subject: Bleed resistor?
PostPosted: Tue Jan 01, 2013 9:14 pm
Was thinking about adding a bleed resister to unload the caps when the amp is off to make it easier to wofk on...
I noticed in the back of the manual that it says that the sIII does not have one...so by omission does that mean that the Plexi already has it and i dont have to worry about it?
 Post subject: Re: Bleed resistor?
PostPosted: Tue Jan 01, 2013 9:54 pm
None of the amps have them.
220K 2W from first filter cap to ground.
PostPosted: Wed Jan 02, 2013 10:18 am
so...i can add the resistor like this then...right?
the filtering caps on the board are already connected to ground...so, do they need to be discharged as well before servicing?
PostPosted: Wed Jan 02, 2013 10:54 am
Yep that's how you do it.
All the caps (including ones on the board) will be drained when you turn off the amp.
PostPosted: Wed Jan 02, 2013 11:10 am
thank you sir...
gonna head over to a guitar shop and pick up a resistor and some sheilded cable...and should have it running by the wkend...time permitting!
PostPosted: Fri Jan 04, 2013 5:54 pm
simplest to just go across the can cap terminal from B+ to ground tab. easy peasy.
