It is currently Fri Apr 04, 2025 8:39 pm
 Post subject: Bangkok Build
PostPosted: Sun Aug 25, 2013 6:25 am
Building my 5th trinity
As always, a true joy to open a pkg from Stephen.
Very neat indeed.
Anyway, got started.
And thought i'd post as i make some progress.
Any comments are welcome.
If you spot an error, i'd like to know.
Or have any advice on doing it better.
www.paradisepi.com
 Post subject: Re: Bangkok Build
PostPosted: Sun Aug 25, 2013 8:59 am
Do you have a .0022 tone stack cap in there or .02 uf? Should be .02 so if not, it will work but it should be changed eventually.
PostPosted: Mon Aug 26, 2013 6:56 am
Todays effort.
Stephen, if you would be so kind as to check that i have wired the transformer correctly for 240V.
And if anybody spots an error, please let me know.
www.paradisepi.com
PostPosted: Mon Aug 26, 2013 8:23 am
Check the Transformer primary wiring for 240 V. Doesn't look right to me, but hard to tell in the photo.
PostPosted: Mon Aug 26, 2013 8:40 am
Well, i kinda hard to understand from the layout, exactly what to do.
Here's a link to a highres pic.
https://dl.dropboxusercontent.com/u/575 ... former.jpg
www.paradisepi.com
PostPosted: Mon Aug 26, 2013 8:48 am
I think it's clearer in the manual. Check the schematic in there.
Connect the Black/White to Black.
Then 1) connect the Line side (from switch) of the Mains to the Black/Red lead, and 2) the Neutral side (from power cord) of the Mains to White.
PostPosted: Mon Aug 26, 2013 8:55 am
Good pics and story here on a head build , from Australia
viewtopic.php?f=16&t=3188
PostPosted: Mon Aug 26, 2013 11:10 am
Thanks, i think i got it now.
www.paradisepi.com
PostPosted: Tue Aug 27, 2013 4:55 am
Ok, all done.
I think i got the Power wiring.
I would however appreciate any comments.
I know, not the prettiest build out there.....Its been a while.
But i just finished up, and went through it all, and it looks good to go.
Anyway, if anybody's around please take a look and let me know if you spot anything wrong.
Pics.
www.paradisepi.com
PostPosted: Tue Aug 27, 2013 7:55 am
Ok, got it fired up.
I am not an expert in measuring power.
But it seem to me something is wrong.
Allthough i have sound i think it is not nearly loud enough.
It just be me who is used to louder amps though.
But it plays. Nothing blew up......hehe.
www.paradisepi.com
PostPosted: Tue Aug 27, 2013 9:49 am
Is there a ground wire to the filter caps from the power tag strip?
Post your voltages when you run B+ up to 400V with the 6V6.
PostPosted: Tue Aug 27, 2013 10:46 am
I think so....
Im a bit rusty, and an amateur at this.
Do you have a tutorial on how to measure the voltages.
www.paradisepi.com
PostPosted: Wed Aug 28, 2013 7:46 pm
Voltage Tutorial is in the Tramp Manual:
Working Inside A Tube Amplifier Safely pg. 42
Making a Voltage Measurement pg. 43
PostPosted: Tue Oct 22, 2013 11:20 pm
Good pics ...
