It is currently Tue Mar 31, 2026 6:37 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Thu Oct 03, 2013 9:23 am
OK! Sounds like everything is in order then! Yes she is working... will be starting the cabinet build this weekend hopefully.
What do you think about the strange squealing sound I get in the amp when I touch v1 pin2 & 6?
PostPosted: Fri Oct 04, 2013 9:02 pm
any thoughts anyone?
PostPosted: Fri Oct 04, 2013 9:32 pm
If the amp is working normally, I wouldn't about the strange noises you get when probing V1. As Stephen said, some noises are to be expected when touching grids and plates with a meter probe. Just to be sure you don't have any bad connections you could wiggle those pins a bit with something non-conductive like a chopstick (with the amp running and one hand in your pocket). You shouldn't hear any weird noises.
Good luck with your cabinet!
PostPosted: Sat Oct 05, 2013 1:21 pm
Thanks Mitch :) I went down to the lumber yard just now and got myself self a bunch of wood. I'll keep you guys posted!
