It is currently Sat Jun 28, 2025 3:23 pm
PostPosted: Tue May 28, 2013 4:16 pm
Hi all. It's been awhile since I've posted as I've been busy with a move, renovations, etc...anyway...
I built my 5e3 a few years ago and it's serviced me well. A few months ago I started to get crackle/pop noises when playing at high volumes. I opened it up and poked around with a chopstick and couldn't find any loose connections. I also swapped out tubes with no difference. I haven't played it for a month or so and fired it up today. I tested it at high volume again with the same result and then the volume dropped out to maybe 10% of what it should be. The strange thing is that it seems to keep the same tonal characteristics. For example, plugged into the bright channel I can adjust the normal volume and get the breakup and clean just like always, just at a very low volume. Before I jump in I thought I'd throw it out there to see if other 5e3 owners might have experienced something similar. Thanks for any help.
-Duke
PostPosted: Tue May 28, 2013 10:59 pm
First start with the voltage measurements and post them. We can go from there. Did you also change your rectifier tube?
PostPosted: Wed May 29, 2013 9:26 am
Voltages
V1. 1-141.5
3-2.23
6-138
V2. 1-186.7
6-225
7-17.3
8-45.2
V3. 2-382
8-22.3
V4. 3-384
4-356
8-22.2
V5. 2-409
4-375
6-375
8-409
Filter caps measure as follows: 389, 356, 268
After checking voltages I plugged in and the volume was back to normal. But it still cuts out at high volume especially when attacking high notes. I changed all the tubes with no difference. I held a note and lower volumes and poked everything I could with no audible results. I cranked it very high and managed to get it to cut out to low volume for about three seconds and then the volume jumped back to normal. ???? :hmmm:
PostPosted: Wed May 29, 2013 10:30 am
Your plate voltage on V2 (pin 6) is low.
Did you mean to measure the voltage on pin 6 of V3?
Could be a bad plate resistor on V2, could also be a loose connection around there.
PostPosted: Wed May 29, 2013 11:42 am
See updates above.
PostPosted: Wed May 29, 2013 1:13 pm
Ya so your voltages are fine then.
Look for a bad solder joint/connection and/or loose wires.
PostPosted: Wed May 29, 2013 9:12 pm
Sounds like a good next step. It sounded like a power issue so you might start
with rectifier, plate or cathode resistor and ground connections
intermittent ones are so hard to find
PostPosted: Thu May 30, 2013 10:44 am
This morning and desoldered and resoldered virtually everything. I fired it up and after a couple loud notes it dropped to low volume again and stayed there. Think Deluxe tones at apartment level volumes. Again I stayed plugged in and poked around the signal path and all the joints, grounds, etc. It seems stuck on low output now. Does this sound like a bad OT possibility. When I lost one before it farted around a bit and then totally died. I'm not sure how to test the OT but am willing to try if I'm walked through it.
PostPosted: Thu May 30, 2013 4:39 pm
Normally when they go, its lights out, but that is a possibility, although remote. We have spare OTs in stock. What is the part number on your OT?
PostPosted: Fri May 31, 2013 11:13 am
The numbers on the tranny read:
108-M
HTS-9800
9960935
If you think it's worth a try pm with payment info, Stephen.
PostPosted: Sat Jun 01, 2013 8:28 am
That is the latest design spec transformer. It's very rare for an OT to fail.
PostPosted: Sat Jun 01, 2013 10:07 am
Yeah, I think I have one of the first of the new bunch. I do have a BBQ OT I can test with. If that's the issue I'll order a new one from you, if not I'll pull it apart, test all the resistors, clean it up, and do a rebuild. I need the practice anyway. :lol:
PostPosted: Thu Jun 20, 2013 9:08 am
All good now. Thanks for the help diagnosing the OT, Stephen. :thumbsup:
PostPosted: Thu Dec 19, 2013 9:19 pm
Update...valve two pin two was shorting out. Easy fix but it sounded exactly the same as when the OT went out last time. Glad that's all it was!
