It is currently Sun Oct 19, 2025 1:03 am
 Post subject: TriFly Prototype Video
PostPosted: Thu Mar 13, 2014 11:51 pm
Shawn Dore created a 5:41 Youtube video. check it out here:
http://m.youtube.com/watch?feature=youtu.be&v=izKcaSRGXr0
Shawn is a great blues player and road tests a lot of our amps. He always has one on the go.
When Shawn and I first auditioned the amp, I made some tube changes from 12AX7s to reduce the gain which I though was a bit much.
Then we put in a12BH7 instead of the designed 12AU7 output tube to give it some more heft and body.
These changes helped a lot.
We are currently using a stock Hammond 125B output transformer and I think it's a weak link. I've never been impressed by the Hammond output transformers, so I contacted Phil at Heyboer and gave him a set of specs. We are getting two custom ones made to compare.
Then I contacted Matt at Musical Power Supplies and he wound us a special one as well and sent it up.
So as we did with the original 18 watt transformer, we are repeating and doing a tone taste test with the TriFly output transformers. There will be 4 of them!
Once that is done, we will tailor the circuitry to dial in the tone the players like most.
PostPosted: Wed Apr 23, 2014 7:34 am
Sawwweeet, Coco!
A lot packed into that small package. I look forward to seeing the schematic, etc. when it's finalized.
J-Rock.
PostPosted: Wed Apr 23, 2014 8:08 am
Yup, it's coming after the next studio session I hope.
