It is currently Sat Jul 05, 2025 2:52 am
Post new topic Reply to topic  [ 104 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: Sun Mar 23, 2014 8:21 am
Where does the OT centre tap go to? Normally off the first node? How did you scale that?
Would an extra cap filter before at the VRM do the same thing?
PostPosted: Sun Mar 23, 2014 12:13 pm
I don't have the amp handy but if I remember its like this. Also don't know if i did it the "way" its supposed to be done . But on the other hand its working
PostPosted: Sun Mar 23, 2014 1:32 pm
Only the circuits after the VRM are controlled. Your plates are fed by the Centre tap of the output transformer so it should work.
Did you find you needed the .1 uf across the first 32uf cap?
PostPosted: Mon Mar 24, 2014 9:19 am
as for the 100 nf prolly not just fell victim to esr and diode noise hype
