It is currently Thu Dec 04, 2025 8:44 pm
 Post subject: Tramp trouble
PostPosted: Wed Jun 17, 2015 8:38 pm
Sickening smell of smoke! Amp was performing great today - first time with a KT88 and replaced 1K 5watt on second bias resistor. About the third time I turned it on, my "short" power light on the line voltage came on briefly, followed by a little smoke and no sound. Traced the problem to R17... a 1K 2 watt resistor near the power tube - it was toast. :bugeye: Hi voltage power section is working fine to that point - but with the resistor out, there's no power to the preamp side. Think the KT88 was too much? I've ordered a 3 watt 1K as a replacement for R17. Any other suggestions/precautions?
 Post subject: Re: Tramp trouble
PostPosted: Wed Jun 17, 2015 9:55 pm
Increased screen draw with the KT88 would blow that resistor.
Try another 2W resistor and a different tube before moving on to a higher power resistor.
PostPosted: Wed Jun 17, 2015 10:04 pm
I stayed away from the KT88 and settled on running a 6L6GC for my bigger tube needs. I have read of at least one other builder with a perfectly fine Tramp then swapping in a KT88 and something goes pop, either the tube itself or (in your case possibly) a resistor, whichever gives up first. That's just my observation but I wonder whether the KT88 runs things very close to a tipping point where you can be lucky and have no problems at all, ....or not so lucky.
Exhibit A:
viewtopic.php?f=16&t=3384&start=60#p27066
Disclaimer: That's just a purely subjective observation made by me and probably a wrong one.
PostPosted: Thu Jun 18, 2015 9:36 am
Thanks guys - hopefully the output trans is OK. Had tried a nice reissue Tung-Sol 6L6GC before going to the KT88 - and it sounded great... almost as much clean headroom as the KT. I'll probably go back to the 6L6
PostPosted: Sat Jun 20, 2015 9:21 am
All is well with my intrepid TRAMP, after replacing the blown resistor and firing up a 6L6. I'll be fine-tuning the bias soon... and from what I'm reading.... a current of about 45-50 ma looks good for a 6L6... while the KT88 likes a higher reading, like 60+ ma. Any suggestions for a target range on bias?
PostPosted: Sun Jun 21, 2015 3:40 am
My measurements for a 6L6GC are recorded in this thread (linked), hopefully that will give you an idea of ballpark numbers.
viewtopic.php?f=16&p=25603#p25603
If built to spec you should be pretty much good to go with a 6L6, being a Cathode biased amp it should come in at just under 30 Watts dissipation with the VRM at Max.
PostPosted: Sun Jun 28, 2015 12:09 am
I have a KT88 in a Tramp and have not had a problem, tho I think the 6L6 is the "bees knees " in this amp!
