It is currently Tue Jan 20, 2026 11:45 am
PostPosted: Mon Oct 26, 2015 4:07 pm
Hi All,
First I'd like to say what a great resource we have in this forum!!! Special thanks to Stephen & co.
I'm working on the TC-15, my first-ever amp build. I started by checking the BOM and all the parts seem to be there. However, I began installing the hardware and it seems like I'll very quickly run out of #4 Hex nuts. So far I've put one each the three 3-tag terminal strips and only have one hex nut left. Still need to do the 5-tag terminal strips (2 nuts) and turret board (4 nuts). What am missing?
Thanks in advance!
A.S.
PostPosted: Mon Oct 26, 2015 7:50 pm
The turret board requires #6 hardware IIRC, but check and confirm
Sounds like you might be missing one #4 nut. Email Trinity. Sometimes small parts like nuts can go missing when putting together a kit. Lots of small parts!
PostPosted: Wed Oct 28, 2015 12:15 pm
PostPosted: Fri Nov 13, 2015 10:46 am
Yes, #6 onturret board, #4 on tag strips BUT, the chassis is tapped so you dont need nuts!!
PostPosted: Fri Nov 13, 2015 12:11 pm
Excellent, thank you!
