It is currently Sat Nov 23, 2024 9:43 am
PostPosted: Wed Apr 13, 2005 5:37 pm
Oh, sorry, same voltage drop as 5U4 :?
PostPosted: Thu Apr 14, 2005 6:34 pm
The West Labs tranny has 5V tap and I confirmed with Dave that it can handle 3A, so the 5Y3, 5U4 can be substitued for the 5AR, no problem (except maybe the stand-by in the long term).
Try it and let us know how it sounds.
Shameless plug time... The s2 Lightning PT sports a 3.25A rectifier tap, so a 5U4 is no problemo.
--s2
www.s2amps.com
www.category5amps.com
PostPosted: Thu Apr 14, 2005 10:06 pm
No problemo, it's a great feature of your PT. Thanks for doing it!
PostPosted: Tue Apr 26, 2005 2:33 pm
The 5U4 draws a lot of current for sure, but I do not know if the extra capacity and overbuild exists in the Matchless Lighning trannies, but I know S2's trannies are engineered to supply the extra current from a thread in another forum. Consider this if you are building an amp.
I have an 52 Gibson amp that uses a 5U4 and it has no stanby switch. I must strip the cathodes every time I turn it on, but the NOS rectfier I have in there seems to take the abuse pretty well.
An unmentioned bonus is that as NOS tubes the 5U4's are cheaper than GZ34's.
PostPosted: Tue Apr 26, 2005 6:09 pm
The West Labs stuff specs 3 amps of 5v on both their 15 watt and 30 watt PT's. I assume any other iron used by Matchless will have the same specs.
Bear
PostPosted: Mon Jun 13, 2005 4:56 pm
why no standby? westlabs sells that triple throw switch that I'm going to use for a standby.
PostPosted: Mon Jun 13, 2005 6:16 pm
Yeah, I like that thing. I'm sold on it just conceptually. For those who don't know, it's got two decks so the one switching power at the three throws is off-on-on, standby is off-off-on, so it's all on one switch. Why didn't anyone think of that before? Great upgrade idea on vintage, too.
Bear
PostPosted: Mon Jun 13, 2005 8:01 pm
Bear
Has anyone found these anywhere besides WestLabs? I've been looking all over.
PostPosted: Wed Jun 15, 2005 5:14 am
I used 642-644H2 from Mouser in the tremolo Lightning I just finished. It has the progressive circuit and has worked great thus far.
Eddie
PostPosted: Thu Jul 14, 2005 10:22 pm
Eddie
More expensive than the West Labs on it appears...
PostPosted: Sun Jul 24, 2005 1:12 pm
From my experience with the taboo amp, the 5Y3 provides quite a good amount of start up delay....it's probably fine to use in an amp without a standby....
but I'll defer to s2 and coco for the final word on that....
PostPosted: Sun Jul 24, 2005 1:26 pm
I would think that a standby switch would be preferred in this case. I know s2 has used a 5Y3 on a 15, so lets see what he has to say.
PostPosted: Wed Dec 07, 2005 10:31 pm
8)
I know this is an old thread but how did the test with the 5Y3 come out? I have an old GE 5U4GB in the drawer that came out of an old HiFi.
Prolly going to build my Lightin' this month as I have now sold all my prototypes.
Thanks!!!
CR ><>
WoodCross Amps
PostPosted: Wed Dec 07, 2005 10:39 pm
I know s2 likes the 5Y3, I've never tried it, just the 5U4
PostPosted: Thu Dec 08, 2005 12:37 am
I have a 55 Tremolux that I've been using a 5y3 in for years. I recently put a EH 5U4 in it. The 5Y3 has a lot more "Sag" at higher volume settings. With the amp dimed ( or more like "Twelved" ) :lol: and hot humbuckers, it will almost "squat" and completly brown out. The 5u4 tames that tendancy very well.
Hope that helps. Heck, for ten more bucks you can try both yourself.
LeeMo
PostPosted: Mon Dec 12, 2005 5:08 pm
David Allen also sells the progressive off-on-on 2 cirucuit switch for about $7. I've used them for several builds and like it a lot more than a separate stand-by switch.
Broz
PostPosted: Mon Dec 12, 2005 11:34 pm
Broz
Whre is David located?
PostPosted: Tue Dec 13, 2005 8:21 am
Stephen,
He's in Kentucky. http://www.allenamps.com/ The switch is his part numer SW (Carling progressive $7). He also sells good transformers for fender type amps and a low priced single-ended OT that has gotten good reviews.
Broz
PostPosted: Sun Jul 09, 2017 12:43 pm
Bumping an old thread.
I'm interested in swapping the rectifier from GZ34 to a 5R4, similar to what a lot of AC30 owners seem to do.
As far as I can ascertain this will not harm the amp, has anyone tried this?
Users browsing this forum: Google [Bot] and 32 guests
