It is currently Tue Dec 02, 2025 9:04 am
PostPosted: Sun Apr 09, 2017 4:51 am
Hi
after rebuilding my plexi on a vox Chinese chassis ( tricky ) I have no sound at all
checked voltage all are correct except pin 2-8 and 7 on V3 6V in place of 60 V
swap tubes and check ground preamp but no way ..
any suggestions ?
thx
jean
PostPosted: Mon Apr 17, 2017 8:55 am
Is this our plexi 18 watt? Always check your ground points and power supply points and jumpers.
PostPosted: Tue Apr 18, 2017 9:33 am
Yes this is the trinity plexi 2009 model I bought from you
Ground is ok maybe this is TMB volume pot or tone normal chanel pots
I m going to shunt 470K and 470R resistor
Thx for the advice Coco
PostPosted: Tue Apr 18, 2017 5:20 pm
If the plate voltage (pin 1 & 6) are OK, then the issue has to be a connection. I would suggest the jumper between 470K-470R-470K or the 56K resistor to ground. Check all and the wiring around this carefully.
PostPosted: Fri Apr 21, 2017 2:25 pm
Ok its working
bad labeling from my resistor supplier , i need to learn color code :)
PostPosted: Fri Apr 21, 2017 7:57 pm
jjleto wrote:
Ok its working
Its good practice to measure components to conform their value! Hard to resist putting them straight in tho!!
Glad its working, which reesistor was it?
PostPosted: Mon Apr 24, 2017 4:28 pm
470k And 470R swap
PostPosted: Tue Apr 25, 2017 1:19 am
I guess brown and yellow could look similar. Usually it's red and orange that get mixed up.
Yes, it only takes a few seconds to verify that the resistor is right with an ohm meter and it saves a lot of headaches later. Especially with 1/4 watt resistors that use a four-band color code, but those won't show up in tube equipment.
I also check capacitors before installing since my meter can measure those, too.
PostPosted: Tue Apr 25, 2017 11:47 pm
Good advice. :thumbsup:
