It is currently Tue Jan 20, 2026 10:58 am
 Post subject: Overdrive Footswitch
PostPosted: Fri Jul 14, 2017 6:40 pm
I'm unclear as to where I pull the +5volts DC to power the foot switchable OD board….
Are there any pics of these connections?
thanks!
 Post subject: Re: Overdrive Footswitch
PostPosted: Sat Jul 15, 2017 3:58 pm
I mean...I see zaphod's pics but they are too clean and tidy to get a complete understanding of where that 5volt source is.
Anyone?
Thanks.
PostPosted: Sat Jul 15, 2017 10:24 pm
I do belive theres a second filament transformer in hi amp look on the right side of his build you will see it.
PostPosted: Sun Jul 16, 2017 3:31 pm
That is correct. A separate 5V regulated supply is on a small board
PostPosted: Tue Jul 18, 2017 7:17 pm
Ok. I mostly see what's going on. 110v to the big board. Then +/- 5 volt from that card to the relay.
He way I've wired it up is wrong. No signal without a plug in the jack. The clean pic in zaphod's build has a different push/pull pot than I've got and the hook up isn't clear. Anyone have pictures or a layout that shows the foot switch hooked up correctly ?
Thank you. You guys are the best.
PostPosted: Tue Jul 18, 2017 8:42 pm
Go to the last reply in this post.
viewtopic.php?f=12&t=1567&p=34589#p34589
PostPosted: Wed Jul 19, 2017 9:37 am
Thank you!!! I'll dive back in today
