It is currently Wed Dec 03, 2025 1:44 pm
 Post subject: 5E3 input jacks
PostPosted: Fri Nov 03, 2017 11:23 am
Is it normal for this to happen? When the amp is on and I tap any of the input jacks hot wires it's makes a microphonic sound. I have nothing plugged into to these jacks. I think there's a problem. I have also replaced the 12ay7 tube, didn't make any difference. Any ideas? Thanks
 Post subject: Re: 5E3 input jacks
PostPosted: Thu Mar 15, 2018 8:08 pm
Ive never tap on the wires . but maybe a cold solder joint. IF you tap on the input jack win a pick does it occour ?.
PostPosted: Sat Apr 14, 2018 3:06 pm
Any vibration can be picked up by a tube. Having aid that, I've also never tapped an input wire. But I have tapped a tube and a board, and sometimes hear the tapping through the tube.
