It is currently Sun Apr 20, 2025 11:01 am
PostPosted: Mon Jan 09, 2006 11:17 pm
The other Project I was working on was put on hold while I finished this one up.Another Lightning is born. I still havent turned it on yet, I havent had the time In case something is wrong I want to have time to look at it.
Here are a few pics untill I can post some news of the startup. The circut is pretty close to the layout I used. As you can see the Chassie and cage is where all the time was invested. Not that I cut any corners on the inside. This one is made out of .060 aluminum bent & welded together. I left a 320 grit brush finish on it & sprayed it with clear Ureathane. I have done others that I polished to a mirrior finish but that is really a nightmare, try it some time if you want to drive yourself insane. For the cage I was going to buy some mesh I saw at a hardware store but it just wasnt exactly what I wanted it to look like. I figured out what size it had to be cut a flat sheet layed out all the holes & proceded to center punch and then drill 900 1/8" holes. then I drilled them all out to 5/16" & hit all 900 both sides with a 60 degree counter sink, then I bent it to the shape I needed made the ends with rolled beads & rolled edges on the finger holes & tig welded it together. Maybe 7-8 hours total just in the cage. I made the feet out of 3/4" bar stock on a lathe. . . Let me know what yuo guys think. . . . JOE
PostPosted: Tue Jan 10, 2006 12:43 am
ART - Pure ART! Great job. So cool looking, I thought I was in the control room! 8) Awesome!
PostPosted: Tue Jan 10, 2006 4:22 am
Joe,
All I can say is your chassis never cease to amaze! That thing is incredible :D
Eddie
PostPosted: Thu Jan 12, 2006 8:18 pm
Very cool. 8)
PJM
http://www.diyguitarist.com
PostPosted: Sat Jan 14, 2006 6:56 pm
Gorgeous. Very 50's space-age cool. Since I didn't take metal shop in school, I'll be stuck w/ Hammond chasis, though.
Bear
PostPosted: Fri Feb 17, 2006 2:35 pm
8) Cool!!! Outstanding workmanship!!! Have ya had a chance to test her out yet???
CR <><
WoodCross Amps
PostPosted: Fri Feb 17, 2006 10:21 pm
Nice work! Saves building a cabinet.
