It is currently Wed Mar 04, 2026 7:57 am
 Post subject: 18watt v6 slll build
PostPosted: Mon Sep 04, 2017 7:17 pm
This is my first amp and after a busy few month or two I was able to start.
I am not a complete beginner when it comes to any of the skills needed and am well versed in how tube amps work . Anyway all help/comments/suggestions are welcome if you see anything wrong don't be afraid to call me out. I will be adding the VRM module after completing the amp
 Post subject: Re: 18watt v6 slll build
PostPosted: Tue Sep 05, 2017 9:53 pm
looks fine so far.
PostPosted: Wed Sep 05, 2018 3:50 pm
Took a break because this year was busy for me but I’m back at it and I have almost finished the power section
PostPosted: Wed Sep 05, 2018 10:52 pm
good tome to test the raw ac voltages!
PostPosted: Sat Sep 08, 2018 6:13 pm
Yep checked the voltages though I ran into something that confused me slightly the schematic call for the c10 capacitor to have a value of 50uf and I don’t have any of those but I do have 47uf capacitors are those what’s supposed to be used in that spot also are the non polarized 502 code capacitors supposed to be the .0047 capacitors
PostPosted: Mon Sep 10, 2018 3:51 pm
Also the kit is missing the r15 470ohm resistor does it matter what type of resistor I use to replace it (carbon film metal film etc.)
PostPosted: Wed Sep 12, 2018 11:29 am
normally a carbon comp but a carbon film or metal film is fine.
PostPosted: Sat Sep 15, 2018 1:45 pm
Finished the amp now having some troubleshooting issues the volume on the normal channel is really quiet and there is no volume on the tmb channel. What I was going to do to start was check all my connections and make sure everything is in the right place
PostPosted: Wed Sep 19, 2018 1:05 pm
Meaure all the voltages. Compare to the chart.
Check all grounds and jumpers and connections to/from the board.
Make sure all the above board turret jumpers are in place correctly.
PostPosted: Fri Aug 30, 2019 8:29 pm
So I got the amp trouble shooting done by a local amp tech but I’m running into a problem where the amp sound sputtery when the vrm is turned all the way up
PostPosted: Sat Aug 31, 2019 2:36 am
Wow. Two years to build an amp! I've had projects like that, too, but they weren't guitar amps.
Anyway, recheck all your wiring and solder connections. Make sure all the parts are in the right places. Also, you could try bypassing the VRM for now and see how the amp works. I'd get an amp working normally before I did anything that messes with the B+.
Also, have a look at the VRM builder's guide in the Support section on this site. It says to modify the preamp inputs a bit by adding some capacitors and moving the 1Meg resistors if you use a VRM.
VRMs are simple circuits and they can be handy things to have, but they can cause builders a lot of trouble.
PostPosted: Sat Aug 31, 2019 2:55 pm
Agree . Run it without the VRM first to establish your baseline. Let us know how that works. Didn't the amp tech test it at max ?
PostPosted: Sat Aug 31, 2019 11:39 pm
Actually played the amp a bit more and problem only happens with the 6v6s so I changed the 6v6s and the problem was still there. Also I noticed the problem is affected by the vrm but I think now they might be unrelated I might have accidentally plugged the output of the amp into essentially a dead short with the power turned up anyway just brainstorming and looking for things to check it sounds amazing besides this issue and overall even though it took 2 years I am satisfied with how it’s going. Also the el84s work perfectly and the sputtering is like a gated fuzz pedal. I doubt the problem is the OT
Because of the el84s working perfectly maybe the bias circuit or the plate voltage? I’ll measure them when I get a chance
PostPosted: Mon Sep 02, 2019 8:11 am
Check that the grid leak resistors for the 6V6 are in correctly as they connect to the EL84s. And heck the bias voltage too.
