It is currently Wed Mar 04, 2026 10:46 am
 Post subject: Vrm question.
PostPosted: Wed Sep 26, 2018 6:12 am
Hi, i have a vrm installed on my 18w ,with the amp and gain volume on 10 . When i drop the volume pot of the vrm is below 3h (3/4) i lost a lot of gain . Is it normal?
Thank you
 Post subject: Re: Vrm question.
PostPosted: Sat Sep 29, 2018 8:20 am
Are you controlling the whole amp or just the power section. I would not expect a big change in tone if it was the whole amp.
PostPosted: Sat Sep 29, 2018 7:37 pm
Yes the whole amp and when i lower the vrm pot i lost a lot of gain ...
PostPosted: Mon Oct 08, 2018 9:17 pm
Thank you
PostPosted: Fri Oct 12, 2018 7:41 pm
I do loose gain with the setting from just on till about 11 o'clock. I've done this with el84's and 6cm6 (6v6).
If I'm playing with low voltage tend to use an ep booster to make it up
