It is currently Thu Apr 16, 2026 12:31 pm
 Post subject: LED won't fit
PostPosted: Sat May 11, 2019 1:40 am
Hi everyone. This is my first amp build. I'm having a really hard time getting the LED power indicator light to fit on the chassis. I've inserted the LED bezel mount from the outside of the chassis, then pressed the LED in. I just can't get the mounting ring to go around the bezel. The ring will fit when the LED is not in the bezel, but when the light is in the "legs" get pushed out just enough and no amount of force that I have been able to apply (with hands or tools) will get the ring to slip on. Am I doing something wrong? Thanks!
 Post subject: Re: LED won't fit
PostPosted: Sat May 11, 2019 2:05 pm
Is the LED pushed as far into the bezel as it will go? A picture from the front would help, too.
PostPosted: Sat May 11, 2019 5:13 pm
Got it in! A nut driver pushed against the bezel on the front did the trick.
PostPosted: Sat May 11, 2019 5:27 pm
Good that you solved it. Good luck with the rest of your build and welcome to the forum!
PostPosted: Sun May 12, 2019 5:09 pm
Glad you got it in. Keep us posted on your build and post questions for any help. Everyone on here has needed it at one time or another.
Cheers!
