It is currently Sat Dec 13, 2025 11:11 pm
PostPosted: Sun Jan 29, 2006 12:29 pm
A customer had a fried Musicmaster Bass Amp that he had me convert into a Spitfire/18Watt hybrid T-bolt 9.
The Musicmaster Bass chassis is the same size as a BF/SF Champ so it was a little tight in there...
WoodCross Amps
PostPosted: Sun Jan 29, 2006 12:31 pm
WoodCross Amps
PostPosted: Sun Jan 29, 2006 4:26 pm
Nice job. Where does the 18 come into play? How did you 'cross' the two?
PostPosted: Mon Jan 30, 2006 12:47 am
Nice faceplate graphics...
PostPosted: Wed Feb 01, 2006 5:46 pm
Steven;
Node Resistors are the closer to an 18 Watt, 470K Grid Leaks for more power amp distortion, Grid Stoppers are between the 18 Watt and Spitfire at 1.2K, PI is 18 Watt, 18 Watt OT.
BTW, this has the Version 3 Mod. It has a Bright Switch and a Boost Switch that kills the Tone Control. Surprising how much Gain that one tone control sucks. It sounds awesome.
CR <><
WoodCross Amps
PostPosted: Wed Feb 01, 2006 5:47 pm
Thanks!!!
CR ><>
WoodCross Amps
