It is currently Thu Apr 16, 2026 12:32 pm
PostPosted: Wed Nov 27, 2019 9:12 pm
Hello everyone from Northwestern Ontario.
Opened it up, reading over the instructions.
Deciding what configuration I will build. Head & cab, combo?
Likely build a combo.
I have a WGS Blackhawk Alnico speaker coming. I will see how it sounds with that. Speakers I also have to try, Eminence Red White & Blues, Celestion Greenback, Celestion Vintage 30.
We will see what it likes. :D
Scott
PostPosted: Thu Nov 28, 2019 7:11 pm
You picked a good one :!: The head version is a little more difficult because of the tube location as some of the socket locations are under the back edge of the board. If you got the combo version, it's pretty easy to convert, socket mounting screws are tapped and all you have to do is drill the actual socket openings.
PostPosted: Tue Dec 03, 2019 12:19 am
Coming along. Worked on it this weekend.
Wiring this evening.
PostPosted: Tue Dec 03, 2019 1:59 am
All wired. Now double check everything.
PostPosted: Tue Dec 03, 2019 1:16 pm
Looks good, I can't see it in your final photo, is the blue jumper there between eyelets 3 and 2 on the Bass control? and thanks for the gut shot , always good to see other people's wiring style. Always looking to improve mine :!:
PostPosted: Wed Dec 04, 2019 12:14 am
Good eyes.
I just took the pliers & bent pin2 over to touch pin3, so when I soldered the wire on, all in joined together.
PostPosted: Wed Dec 04, 2019 1:46 am
Fired up no problem.
No hiss, or hum.
Sounds great!
Thanks Stephen.
PostPosted: Wed Dec 04, 2019 8:25 pm
:thumbsup: :thumbsup: Was just curious
PostPosted: Thu Dec 05, 2019 8:55 am
Neatly done!
PostPosted: Fri Dec 06, 2019 12:41 am
Got a couple more tubes showing up next week.
KT88 & 7581
PostPosted: Sat Dec 14, 2019 10:38 pm
Got some new tubes to play with.
KT88
PostPosted: Sun Dec 15, 2019 6:21 pm
I really like the neat way you laid out your wiring! I'm taking notes...
From the pictures, it looks like you've put the fuse on the neutral side of your mains connection, rather than the hot side. If I'm seeing that right, the fuse won't protect you from hot-side shorts upstream of the power transformer.
Does this match what you see in person?
PostPosted: Mon Dec 16, 2019 2:21 am
You made me double check things, but it was correct.
The lettering is on the end of the input cable.
Scott
PostPosted: Mon Dec 16, 2019 7:31 pm
KT 88 works well in the Tramp, but you'll have to remove the supplied tube retainer clip (tube base too large), if you haven't already discovered that :(
PostPosted: Mon Dec 16, 2019 9:18 pm
Put the 7581 in this evening. Changed the bias switches to 5k & Hi. Sounded great.
Cranked it to the max, it was screaming real nice, then started cutting out, saw a slight bit of the dreaded smoke from the Power tube area, then dead.
Checked the fuse, blown. Replaced & put the tube back in. Glows with a little bit of lightning inside.
No sound.
Bad tube?
Scott
PostPosted: Mon Dec 16, 2019 10:08 pm
Scott, all I can suggest is to check the bias and load switches, particularly the load switch. There have been some problems reported with them arcing on the Tramps and at least one OSD (may have happened on another, but I can't recall which it was). Seems as if it usually happened during cranked up conditions. If it arced, may have taken out the power tube. Just spitballing, may be something else entirely. :hmmm:
PostPosted: Tue Dec 17, 2019 1:07 am
I switched to the EL34, changed the bias & load switch.
Lights on, tubes glow, but nothing.
PostPosted: Tue Dec 17, 2019 5:01 am
Check all the voltages, especially at the output tube.
PostPosted: Wed Dec 18, 2019 12:17 am
I was following the voltage, & before the 5k - 100ohm, 460VDC, but nothing after.
Could it have failed?
So then nothing would be getting to the VRM.
Scott
PostPosted: Wed Dec 18, 2019 5:46 am
The resistor could have failed. Does it still measure 100 ohms? It could also be a bad connection to the jumper that goes to the Mosfet.
