Another update:
While I was getting ready to build the board, I stumbled on this video (
https://hackaday.com/2015/05/20/how-to- ... backwards/). It's long, but you can watch it in fast-forward and skip the repetitive parts. It suggests that you can reduce noise and hum in your amp by figuring out which leg of each tubular cap is connected to the outermost layer of foil, and connecting that leg to the lower impedance part of the circuit so it acts like a shield around the capacitor. It seemed worth a shot!
In the end (see below) I decided the impact on this build will be minimal. It was still a fun exercise, though, so I'll write it up here.
The first thing I did was simply connect each capacitor directly to an oscilloscope probe & ground, then reverse the leads. I didn't take a photo, but I was trying to duplicate what's shown in post #19 of this TDPRI thread (
https://www.tdpri.com/threads/lunchbox- ... ed.992175/). It didn't work well. The variation in signal strength just from moving things around was bigger than the effect of swapping the leads. I wasn't able to figure out which lead was connected to the outer foil.
So I decided to build a testing box like the one in the video, but with a mechanical switch instead of a PCB and solid state relays.
File comment: Here's what I was shooting for
where all of the shields and the scope ground are tied to an aluminum case. I had this project box on hand. It's aluminum, and about the right size, so I used it.
File comment: 4.4" x 2.4" x 1.2" project box
I put the hole for the switch and the holes for wires on opposite ends of the box, so I can work the switch without getting too close to the capacitor and oscilloscope probes.
File comment: A hand drill would have worked fine, too.
I didn't have any spare shielded cable to use. I thought about cutting up a guitar patch cord, but I didn't want to use cable that thick. In the end I found an old RCA-to-RCA video patch cord and used that. Here's the whole thing wired up.
File comment: Internal wiring
The copper braid on each pair of shielded wires is twisted together and soldered to a piece of single-conductor stranded wire. Those two single conductor wires "Y" together into a single wire that runs to the project box. I connected it to the project box by soldering it to the locating tab on the switch mounting washer.
Here's what it looks like on the outside. To keep the wires from sliding in and out of the grommets I used zip-ties on the inside of the box and heat shrink on the outside.
File comment: Nearly done...
Finally, I put ring lugs and alligator clips on the wire ends. I forgot to tie the scope ground line to the case when I was wiring up the inside, so I simply connected the shield and inner conductor at the ring lug.
If your scope has a low-pass filter or bandwidth limit, it helps a lot to turn that on. Here are pictures at full bandwidth (50MHz on this scope) and with a 20MHz bandwith limit turned on. You can see that the signal with the limit engaged is much cleaner. The toaster is there just as a good source of 60Hz interference.
File comment: Without the bandwidth limit
File comment: With the bandwidth limit
Finally, here's the switch in the other position. With this cap (0.01uF), there's a noticeable difference. With larger caps the difference gets much smaller. I think this is because the larger caps have lower impedance at 60Hz, so the hum simply couples through to the grounded leg regardless of switch postion.
File comment: Less hum in this position
This was a lot of fun, but in the end I don't think it will have much impact on the tramp build. After doing this, I went back and had a good look at the schematic. Only one of the tubular capacitors (C3) is connected to a truly low-impedance part of the circuit, so this is the only tubular cap where I imagine getting the orientation "right" might make a real difference.
Wow, this post got long!
