It is currently Fri Apr 24, 2026 1:10 am
PostPosted: Sat Mar 20, 2021 2:01 pm
I just received my 5E3 kit and was wondering If it is better to scuff up the chromed chassis metal with sand paper or Dremel to create a better grounding surface?
PostPosted: Sat Mar 20, 2021 4:11 pm
There are no Keps nuts for the #4 bolts that attach the tube sockets in my kit supplies. The tube sockets need nuts on them to keep from vibrating off. Are they not supplied on purpose?
PostPosted: Sat Mar 20, 2021 4:25 pm
The chassis holes for the tubes sockets are threaded. You shouldn't need any nuts (KEPS or otherwise) for the sockets to be mounted securely.
PostPosted: Sat Mar 20, 2021 5:52 pm
Yes, I called Stephen and he said to put some loc-tite on the screws. There's a lot of vibration on amps and I was concerned about loose bolts.
 Post subject: Tube socket orientation.
PostPosted: Sat Mar 20, 2021 5:55 pm
It seems the tube socket mounting holes don't match the #1 pin position on the chassis diagram. the #1 pin is 45 degrees off from the alignment shown on the chassis diagram. Am I doing something wrong?
PostPosted: Sun Mar 21, 2021 7:19 pm
Use the guide as a guide. You aren't doing anything wrong. Sometimes the drawing are sketches for direction.
 Post subject: Parts question.
PostPosted: Mon Mar 22, 2021 10:00 am
There are 2 small black plastic grommets that I cannot find a use for in the instructions.
What are they used for? I don’t want to go any further until I know.
PostPosted: Mon Mar 22, 2021 11:05 am
For output transformer lead protection through 1/2” dia holes on top of chassis
