It is currently Sun May 26, 2024 8:59 am
 Post subject: HT fuse for Thor kit
PostPosted: Tue Nov 09, 2021 10:26 pm
I just realized my kit only came with a mains fuse. I'm not exactly sure why. What value should I use if I add an HT fuse?
 Post subject: Re: HT fuse for Thor kit
PostPosted: Mon Nov 15, 2021 6:14 pm
Interestingly, most of the 18 watt schematics I've seen do not use a HT fuse. However, I suppose you could use a 0.5A FB between the power supply center tap and ground, similar to the JTM.
Read this from the old 18 watt forum:
https://www.18watt.com/viewtopic.php?p=192209&sid=980af41036e6008bd5744b3a94d096c1#p192209
Here's some good stuff from Merlin (Valve Wizard) on fuses. He opts for 2 fuses on the HT winding prior to the rectifier rather than fusing the center tap:
http://www.valvewizard.co.uk/fuses.html
You could also place safety diodes on the rectifier socket (in series) if you are worried about a short causing PT damage:
https://www.tdpri.com/threads/rectifier ... e3.833572/
PostPosted: Thu Aug 11, 2022 3:38 am
Thank you for sharing PharmRock. Very useful for me
fall guys
PostPosted: Tue Aug 23, 2022 9:40 pm
Thanks, Pharmrock. This is exactly what I need.
LOL Beans
PostPosted: Wed Dec 14, 2022 2:47 am
You're very welcome, PharmRock. Helpful for my purposes greatly.
unblocked gamez
PostPosted: Sat Jul 15, 2023 4:52 am
To determine the appropriate HT fuse value, you should consult the technical specifications or documentation provided by the manufacturer of the equipment or circuit. They will typically specify the recommended fuse rating or provide guidelines for heardle selecting the appropriate fuse. If you are unsure or do not have access to the manufacturer's documentation, it is advisable to seek assistance from a qualified electrician or technician who can help you select the right fuse value for your specific application.
