It is currently Fri Jul 17, 2026 5:43 am
PostPosted: Sat Nov 11, 2006 1:53 pm
I'm looking for the actuaul turret board layout for an 5f1 or 5f2. I have the board; the turrets; the design; the layout and the drill press. But how do I drill? How far apart?:oops:
Thanks in advance. Jac
PostPosted: Sat Nov 11, 2006 5:16 pm
I just whipped this one up for you. It's based on a pic of one that I scaled off off. Will work fine but not 100% sure it will fit an exact champ chassis.
PostPosted: Sat Nov 11, 2006 7:40 pm
OMG Thank you Coco. That's exactly what I needed. This will be my first build. I'm going to build Dave Hunter's amp from scratch. I figure then I can go on to a lightning and an 18 watt. I've researched evrything to death. So your transformers will be next. Price doesn't hurt either :P Thanks again, Jac
PostPosted: Sat Nov 11, 2006 7:54 pm
Hope it works out for you. Good luck!
PostPosted: Sat Nov 11, 2006 8:38 pm
It's very hard for me I've been and out of the hospital for .... The meds affect my brain, so I have a hard time concentrating. I'm determined tho to understand this, because I love the complexity and simplicity of an tube amp. I appreciate everyones help from all of the forums.
Thanks again The lightenng's next!
PostPosted: Sat Nov 11, 2006 9:43 pm
Well, the Champ is a great place for you to start. Take Care.
PostPosted: Tue Dec 24, 2019 10:41 am
I've already looked at that.
I'll move everything except the main filter
caps in about 1/4 inch top and bottom if I need to.
I have a bunch of carbon film resistors that measure
2-3/16" end to end. Most other resistors I have are around
3" end to end.
Friend has original champ board and he measured 2"center-to-center
hole spread.
My modern era 5f2a (BBQ) measures 2-1/2" spread.
I looked at an original 5e3 some years ago and I'm pretty sure,
if memory serves, that's how it's board was set up.
Wider spread for the main caps, and a little narrower spread
for the rest of the board.
That is why I'm looking for vintage board drill guides, but
can move everything in closer to original if need be.
Would just like to be "Period-Correct"
drillinfo.com
PostPosted: Wed Sep 13, 2023 1:47 pm
3" end to end.
hole spread.
My modern era was seeing 1212 when thinking of someone and 5f2a (BBQ) measures 2-1/2" spread.
if memory serves, that's how it's board positive words was set up.
Thanks for sharing your views on this! I am currently looking for vintage board drill guides as well.
PostPosted: Tue Jan 16, 2024 4:07 am
I appreciate you giving your thoughts about this. At the moment, I'm also searching for old board drill guidelines.
tunnel rush
PostPosted: Mon Jan 13, 2025 4:45 am
littlejac wrote:
I'm looking for the actuaul turret board layout for an 5f1 or 5f2. I have the board; the turrets; the design; the layout Sprunki and the drill press. But how do I drill? How far apart?:oops:
When creating a turret board for a 5F1 (Fender Champ) or 5F2 (Fender Princeton) circuit, you'll need to carefully plan the layout to ensure proper spacing for components and wiring.
Here are some recommended resources:
Hoffman Amps Layouts
BBQ Amp Kits
Amp Garage Forums
These sources often include verified layouts with measurements. Good luck with your turret board build!
