It is currently Thu Jan 22, 2026 10:55 pm
PostPosted: Sat Dec 04, 2021 9:23 pm
Hi,
I just completed my OSD build and initial trouble shooting. The amp sounds great and is dead silent until the tube fx loop is engaged. There is a small amount of hiss I would like to reduce. I have maximized the send and minimized the return, and connected a 1M resistor from the mv to ground. Does anyone have any other suggestions to reduce hiss in the fx loop?
Kevin
PostPosted: Mon Jul 04, 2022 9:56 pm
I have the same questiondrift boss
PostPosted: Thu Sep 01, 2022 12:10 pm
Hi. New member here and happy to have the privilege to be a part of this forum. Thank you Trinity amps!
I was wondering if any of you guys have resolved your noise issues with the tube effects loop?
Sometimes it can be where you have placed it in the signal chain.
Cheers
Guy
PostPosted: Wed Mar 27, 2024 8:04 am
Have you tried checking the cables and connections in the FX loop? Sometimes using shielded cables and ensuring proper grounding can help reduce hiss in the loop like in solar panel.
PostPosted: Thu Oct 24, 2024 12:55 pm
Have you tried just using a patch cable? This way, you isolate whether the hiss is coming from the pedals or not.
PostPosted: Thu Oct 31, 2024 3:14 am
You can try replacing the signal wires and components in the FX loop to reduce noise or use better quality cables.
snow rider
PostPosted: Sun Dec 15, 2024 10:54 pm
To reduce hiss in your OSD amp's FX loop, start by using high-quality shielded cables for all connections to minimize noise. Adding a noise gate can help cut out unwanted hiss when you're not playing. Experiment with different FX loop send and return levels to find an optimal balance. Additionally, check for any noisy tubes in the circuit and consider replacing them if necessary. Lastly, ensure proper grounding and google baseball isolation for your pedals to further minimize interference and enhance the overall sound quality.
