It is currently Sat Jan 31, 2026 11:04 am
PostPosted: Tue Jul 20, 2021 9:13 am
Just got my TC15 kit and the chassis and faceplate orientation is different than the TC pictured on page 18 of the builders guide. The picture shows the tubes and transformers facing down and my chassis and faceplate show the tubes and transformers on top. Are there different chassis es for a head and a combo? What am I missing?
PostPosted: Tue Jul 20, 2021 9:20 am
I think I have the chassis made for the combo because the chassis I have won't work on the head cabinets I am seeing for the TC15. I don't really mind because I want it in a combo set up anyway, just wondering.
PostPosted: Wed Jul 21, 2021 2:37 pm
The back (bottom) of the amp should face the back of the cabinet and be covered by a panel (panel will probably have holes or mesh in it for ventilation). Tip the amp on back edge and I think you'll see how it works.
PostPosted: Tue Mar 12, 2024 6:23 am
In my opinion, you have the correct TC15 chassis orientation. The tubes and transformers can be located on the top or bottom of the chassis, depending on whether you have a combo amp or an amp head. wordle unlimited
PostPosted: Tue Nov 19, 2024 11:41 pm
mikasa wrote:
In my opinion, you have the correct TC15 chassis orientation. The tubes and transformers can be located on the top or bottom of the chassis, depending on whether you have a combo amp or an amp head. Head Soccer
That was the right decision. :happydance: :happydance:
PostPosted: Tue Aug 05, 2025 9:55 pm
Yes — there are different orientations for the TC15 depending on whether it's going into a combo cabinet or a head cabinet.
ragdoll archers
