It is currently Thu Oct 16, 2025 6:00 pm
PostPosted: Sun Mar 17, 2024 6:59 pm
Wondering how to go about drilling the holes for a head cab to receive a Trinity 18W chassis. The square cage nuts are a good idea. However its difficult to mark up drill holes when you cant access the the square receiving holes when the chassis is in place. I'm guessing this question has been asked before but couldn't find it in resources or using a search. Thanks. Dave
PostPosted: Wed Mar 27, 2024 3:41 pm
The drill hole spacings are 19 1/4" x 4 5/8" for the 4 corners. Diagonal dimension to drill holes is 19 3/4 " to ensure its square. At least this is how it is for my Trinity 18W chassis.
PostPosted: Fri Jan 31, 2025 5:29 am
viewtopic.phpdinosaur game
Hi Dave! You seem to be up against it. Using thin cardboard or a template to match with the chassis and mark hole positions may help. You might also loosen the chassis to access the alignment points without removing it. I wish you luck and the right answer!
PostPosted: Thu Apr 10, 2025 4:42 am
A good method is to use a template made from cardboard or thin wood, with pre-drilled holes that match the chassis corners. You can then position the template against the chassis to mark the drill points accurately before drilling.
papa's scooperia
PostPosted: Wed Jun 25, 2025 5:58 am
Using a cardboard or thin wood template with pre-drilled holes that match the chassis corners is an excellent way to go about this. Before drilling, you can precisely mark the drill spots by positioning the template against the chassis.
slope game
PostPosted: Mon Jul 07, 2025 10:25 pm
That's a tricky situation with the head cab. I've had similar alignment issues before. Sometimes, even with careful measurements, things can be a little off. I wonder if the metal might be undergoing some kind of sprunki phase during manufacturing, causing slight variations. I'll try the template idea. Thanks for the suggestions!
