It is currently Sun Apr 20, 2025 8:19 am
 Post subject: Noob Layout Question
PostPosted: Sun Aug 06, 2006 11:29 pm
The Lightning layout shows 2 shielded wires from the input jacks to a terminal strip next to V1, then two 68k resistors converging on pin #2 of V1.
I'm sure there's an obvious reason for this, but is it possible to connect the two 68k resistors at the jacks instead and then run a single shielded lead to V1?
A possible answer just occurred to me - is it because grounding the shield on each lead is easier with the shielded wires connected directly to the jacks?
Thanks for your help.
Chip
noob de lux
PostPosted: Mon Aug 07, 2006 8:58 am
Chip,
There is a good reason to follow this. It is to reduce hum and noise pickup. I highly recommnend that you put those 68K as close to the tube socket pins as possible.
PostPosted: Mon Aug 07, 2006 9:14 pm
Done!
Stephen, thanks for the explanation - knew there had to be a reason.
Chip
noob de lux
PostPosted: Tue Aug 29, 2006 12:46 am
Thsi might sound nuts, but if you're still getting some noise, I actually had one case where I kept pin 2 and 7 connected, but I attached one 68k to pin 2 and the ohter to pin 7. It helped get rid of some trace hum. That's all I needed to know. The coolest tricks on building amps seems to me to be how to keep them quiet. They don't always make a lot of sense.
www.CelticAmplifiers.com
