It is currently Tue Dec 02, 2025 8:14 am
 Post subject: Attaching Plexi Panels
PostPosted: Tue Aug 29, 2006 4:06 pm
How are the plexi panels attached to the chassis. I read of using glue, double sided tape or just the components holding them in place. Any "correct" way to attach them?
Thanks.
ko
PostPosted: Tue Aug 29, 2006 7:16 pm
The nuts on the shafts of the pots, switches, and jacks should be sufficient.
PostPosted: Tue Aug 29, 2006 9:14 pm
Nuts etc. as Mr. db suggested are fine.
PostPosted: Wed Aug 30, 2006 10:16 am
ko
PostPosted: Wed Aug 30, 2006 12:50 pm
The only problem area I noticed was the back panel. The right side as you look at the back isn't held by anything, and has been flapping around as I construct it. I affixed two strips of double-sided tape and it seems OK now. The whole thing will be held in by the chassis I eventually build, but this will work for now.
PostPosted: Wed Aug 30, 2006 3:57 pm
Yes, I suppose this could be a problem catching on something until it's installed. That's a good idea.
PostPosted: Wed Aug 30, 2006 9:31 pm
Grip with your nuts :shock:
