It is currently Thu Aug 27, 2026 8:55 pm
PostPosted: Tue Jun 05, 2007 1:09 am
Hey guys
Summer session is narrowing down, so I'm trying to make my build decisions. On this layout for an AB763 blackface deluxe, I'm really having trouble finding the filtering caps. Can someone point them out?
Also, is the wire running from the cathode (pin 8 ) of V1 to the same on V2 the only thing connecting the normal and vibrato circuits? The only thing they share? Are they otherwise totally independent of each other? So that my mods to one side will not effect the other, making one side my modded side and the other a standard blackface deluxe?
http://www.ampwares.com/ffg/schem/delux ... layout.gif
PostPosted: Tue Jun 05, 2007 6:21 am
It's easeir to follow a schematic:
http://www.ampwares.com/ffg/schem/delux ... _schem.gif
The 4 filter caps are the 16uf/450v close to the transformer. Also a choke.
The only common connection is the plates V1 V2 , going into the Phase Invertor, otherwisse independant and you can tweak to your hearts content.
Check out the schematic.
