It is currently Sat Dec 13, 2025 6:37 pm
PostPosted: Tue Jun 19, 2007 2:01 am
I am looking at the plans for a Deluxe 5E3 cabinet and I don't really understand how the speaker baffle is secured to the front of the cabinet. Does it just get bolted to the front facia, the 1 1/2" pieces at the top and bottom of the front cabinet?
If you have a 5E3 cabinet or have built one, could you please enlighten me?
Cheers.
PostPosted: Tue Jun 19, 2007 2:13 am
Yep, it is secured with two bolts at the top and two at the bottom. I use stainless steel on mine.
PostPosted: Tue Jun 19, 2007 7:56 am
Legin, Great looking cab. Baffle attacehd same as mine. What kind of finish do you put on that Tweed?
PostPosted: Tue Jun 19, 2007 12:42 pm
Thanks for the quick replies. That is a nice cabinet.
Cheers.
PostPosted: Tue Jun 19, 2007 7:22 pm
Stephen, I use a satin boat varnish, I have tried various varnishes and shellacs but this seems to give me the best finish.
Nigel
PostPosted: Tue Jun 19, 2007 8:29 pm
Satin boat varnish. Any particular type or formulation. Company? Full strength?
So much gets said about tinted nitro lacquers etc. Always looking for something better...
PostPosted: Tue Jun 19, 2007 10:06 pm
It's an Aussie made product, I will have a look on the can and send you details.
Nigel
PostPosted: Tue Jun 19, 2007 11:22 pm
To duplicate the Tweed look the general consensus I've heard
is to use Zinsser Bullseye Amber Shellac cut 50/50 (or so) with denatured alcohol (methyl hydrate) solvent, applied with a bristle brush. Multiple coats to achieve the color, and even out splotchiness.
PostPosted: Thu Jun 21, 2007 5:38 am
Haven't tried it yet but supposibly 4 coats is the trick. Should find out soon enough.
PostPosted: Thu Jun 21, 2007 1:45 pm
Zinser's good stuff. It's what many of us guitar builders use to french polish our acoustics.
What might be more appropriate is Z-Poxy.
http://www.lmii.com/CartTwo/thirdproduc ... r=Z%2Dpoxy
I'm not sure what the product number is (Z-Poxy has quite a few), but this is what I use as the filler on my guitars. It'll give you a very nice, warm (natural) amber in likely one coat. It's actually a fiberglass product, so it'll give your tweed more protection than shellac. More durable, unaffected by moisture, etc.
Though it won't cover as many cabinets as a can of bullseye.
PostPosted: Fri Jun 22, 2007 10:16 am
James,
What exactly are you using the Z-poxy for on guitars? For filling in gouges, etc. I've always used woo putty, sawdust, etc... Just curious. Might be better.
Sorry off topic.
PostPosted: Fri Jun 22, 2007 12:49 pm
It's used as a filler. I'll post a pic today.
PostPosted: Fri Jun 22, 2007 2:14 pm
Haven't used it on my guitar repair before.
