It is currently Mon Apr 20, 2026 5:45 am
PostPosted: Thu Jun 28, 2007 7:28 pm
I'm thinking about adding a switch to switch cathode cap values between 10uf and 22uf. I know that you removed the + end from the board and wire it to the switch.
I have four cathode caps and would like to run them all from the same switch. Can I wire the 4 leads of each + end to a single lead, then run that single lead to the appropriate tag on the switch?
I'd have two sets of these. One set of 10uf, and one set of 22. If I can wire a master lead to each set of values, I'll only have two wires coming to the switch instead of 8.
PostPosted: Thu Jun 28, 2007 9:18 pm
I think it may be better to connect common grounds to the switch.
PostPosted: Fri Jun 29, 2007 12:19 am
Hmm. So the + end would connect to the tube and the switch would connect one cap or the other to ground?
Would the master lead work? I don't see why it shouldn't, but want to ask.
PostPosted: Fri Jun 29, 2007 7:55 am
I cant see connecting all the +ve ends that are supposed to go to different tube pins. Unless I got you wrong here. But the common point for all is ground. So you can use a 'master' lead as you describe. Draw it out on paper.
