It is currently Wed Nov 19, 2025 4:57 pm
 Post subject: new dc30
PostPosted: Tue Aug 14, 2007 1:41 pm
I found a pic of a new dc30,
there is a change of the value of one of the caps in the tone stack.
the one from the 100k slope resistor to the wiper of the bass pot is now a 0,1uf cap...
PostPosted: Tue Aug 14, 2007 1:42 pm
http://www.flickr.com/photo_zoom.gne?id ... 4493316540
PostPosted: Sun Aug 19, 2007 3:00 pm
Pretty much looks like spaghetti to me! Thanks for the update.
I much prefer our layout for the TC-15 or modify it for a 30!!
PostPosted: Wed Aug 22, 2007 10:51 pm
moved to 30 watt forum
PostPosted: Thu Sep 20, 2007 11:22 am
Deear god no wonder those things are so expensive!!
PostPosted: Thu Sep 20, 2007 5:08 pm
Honestly, does it sound better because of all the wire dressing, lead tubing and glowing lights?? I don't think so but it might survive being run over by a tank!
It is quite the work of art.
PostPosted: Fri Oct 19, 2007 9:16 pm
well if anything the 30watt layout we did stephen is alot quieter than the real deal. I played a real one and it hummed a bit. Ours - quiet as a mouse!
PostPosted: Sat Oct 20, 2007 12:25 pm
We should really post that good layout. But I think a TC-15 cranked up to TC-30 would be just as good too!
PostPosted: Fri Nov 23, 2007 9:09 am
I think we had software/ file issues back then with you using pc and me using mac. I have coreldraw now so if you want to send me files I can update it.
PostPosted: Sat Nov 24, 2007 4:42 pm
Does your layout look anything like the TC-15? I put the contour caps on the rotary switch to save board space and used a 32/32 can cap, again to save space.
PostPosted: Sun Nov 25, 2007 4:12 am
Yeah sort of. I put all the caps on the rotary switch but all the power supply caps I put on a separate board.
I'll update shortly .
Ta
daz
