It is currently Thu Apr 16, 2026 2:18 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Fri Nov 16, 2012 6:04 pm
Speaker indecision. So, I have decided not to decide. I already have here a couple of Fender/eminence special design 12 inch ceramic speakers in a cabinet that I never use anymore. I think for testing this build that I will just pull one of those and put it in the cabinet to get the Tramp built, up and running. Then, instead of rushing into a purchase, I can take my time, play around with these eminence speakers; see what the amp does, and then make an informed decision about getting a good speaker that fits the Tramp's function in my studio.
PostPosted: Sat Nov 17, 2012 5:18 am
I'm using a Vox Night Train 1x12 cab to test pretty much everything. It has a Celestion Greenback stock that's finally getting broken in and sounds great! I recently got a WGS Reaper 12" 16Ohm and put it in the cab... sounds nearly identical to my ears but a bit cheaper in price.
PostPosted: Sat Nov 17, 2012 10:15 am
I've been using an Eminence Private Jack..their take on the greenback. Sounds very good and not expensive.
Jim
PostPosted: Tue Nov 20, 2012 1:31 pm
As an FYI there's a thread on here somewhere from when I built my Tramp. I had loaded it with a 12" speaker (cut a new baffle myself). Even a 12" Eminence Red Fang with the bell fit in there with a 6L6 and I had no issues. There are pics in that thread.
It sounded FANTASTIC with the Red Fang, BTW, which is 50w.
SG + Brit tube head = Nirvana
PostPosted: Tue Nov 20, 2012 8:51 pm
Cabinet arrived today. It is exactly as ordered. The chassis opening is 10x2.5 [10x2.75 including backpanel offset]. I put the chassis panel in to see if it fit and there is no cabinet overlap and perhaps less than a hair gap; so for those building their on cabs I would reduce the chassis opening by about 3/32 for a slight cabinet overlap; still I am very pleased The speaker opening was moved to the right for Tramp design & to fit a KT88 and Blue Dog down the road. Here are two pictures.
PostPosted: Tue Nov 20, 2012 10:20 pm
The cab looks great. There's actually a lot of leeway/tolerance on the panel for knob throw and clearance of the LED to allow a lot of overlap so the chassis can slide under quite a ways before any "interference" with knobs/LED etc, becomes a problem. Even if you didn't allow the extra .25" for the panel I think you would have been fine.
Snowy
PostPosted: Mon Nov 26, 2012 10:58 pm
I was able to pick up a used Blue Dog Ceramic 15 W. So that is what I am starting with. I also got a new KT88 to push the little dog around with.
PostPosted: Tue Nov 27, 2012 3:15 am
I've pretty much settled on a Sovtek KT88 in my Tramp, it has a certain chime and musicality that the other tubes didn't quite possess; almost like some built in reverb which threw me for a bit of a loop. I had to check to make sure my Cathedral wasn't engaged... a couple times!
