It is currently Sat Dec 06, 2025 4:56 am
Post new topic Reply to topic  [ 240 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 12  Next
PostPosted: Wed Oct 22, 2008 10:37 pm
HarmonyoftheSpheres wrote:
When you get some spare time, or retire :wink: from recording, you need to write your book!
:D Thanks for the kind words Jim. I appreciate it. Glad that all my blabbering is useful. :wink:
Spare time? Retirement? Both of those sound great... but alas, neither will ever happen!!! But who am I kidding - I love my job so much, why would I ever want to retire!!!! :lol:
Brent Bodrug
Producer-Engineer/Songwriter
www.slyfichapel.com
PostPosted: Wed Oct 22, 2008 10:45 pm
zaphod wrote:
Now of course, his hearing is damaged, and IIRC he can no longer hear high frequencies. Such a pity for someone who used to be known for chasing the ultimate guitar tones. I'm sure that if Hendrix was still alive today, his ears would be pretty well shot too - if not his brain. :lol:
OK, so before someone accuses me of being the high-wattage deaf guy, I'd like you all to know that I am NEVER in the room with the amp cranked without earplugs! I've gotten quite used to dialing in tones with the plugs in, and then double-checking in the control room at reasonable levels... :)
Now, my brain, that's another story - I think the vibration from all those loud amps is causing my brain to rattle a bit... :roll:
On a serious note, it's fantastic to have you around Phil. Your insight (and input into the Triwatt!!) are greatly appreciated. :D
Brent Bodrug
www.slyfichapel.com
PostPosted: Tue Oct 28, 2008 5:02 pm
Had a chat with Stephen last night about the Triwatt. OK, so now I'm REALLY excited!!!!!!!!! This amp is going to be THE deal. :D
Brent Bodrug
www.slyfichapel.com
PostPosted: Wed Oct 29, 2008 11:41 am
If it's not too much hazzle or expensive, maybe a 230V tap for the PT could be added? Of course the 240V could be used. Not sure how important the exact voltages are in the triwatt.
My sIIIv6 runs fine with a lower than spec 320V on the tubes.
Just a thought. The only country in europe with 240V is the uk. Everybody else use 220-230V.
PostPosted: Wed Oct 29, 2008 6:02 pm
Thanks. Good point to keep in mind.
So would there be more 220 or 230 V countries?
PostPosted: Thu Oct 30, 2008 7:38 am
Can't say for sure without actual measurements. The EU standard is 230V (-6%, +10%) or 216.2 - 253V. Not very specific is it. :roll: But 240V would be high unless your in the UK.
Here's the wiki link with all voltages.
http://en.wikipedia.org/wiki/List_of_co ... requencies
PostPosted: Thu Oct 30, 2008 7:24 pm
I actually lived in the UK for a few years, where they know what *real* voltage is! :lol: To be honest I couldn't imagine making a British-style amp without an option for 230/240V operation. :)
PostPosted: Sun Nov 09, 2008 12:39 pm
Can we get some pics of the prototyping so far???
:D :D :D
PostPosted: Sun Nov 09, 2008 4:20 pm
Mask For Triwatt Prototype Eyelet Board
Triwatt Prototype Eyelet Board Progress - not soldered
PostPosted: Sun Nov 09, 2008 4:21 pm
Working on the chassis iron layout with the headphones.
Turns out both transformers , on-axis 4" separation or greater is quietest. If I moved the PT off axis, I got hum in the headphones.
Good thing the OT is 6" away in the prototype layout. Time to punch up the chassis.
PostPosted: Sun Nov 09, 2008 7:29 pm
Bare chassis
Template taped onto chassis. Ready to go.
Chassis Punched. Tapping Socket Mounting Holes
Top of chassis completed.
PostPosted: Mon Nov 10, 2008 8:18 am
Chassis Front
Chassis Rear
PostPosted: Mon Nov 10, 2008 4:44 pm
Gawd what a tease!!! :wink:
Great progess Stephen!!! :P
Stew
PostPosted: Mon Nov 10, 2008 10:23 pm
TRIWATT Prototype Front
TRIWATT Prototype Inside View
PostPosted: Mon Nov 10, 2008 10:37 pm
DAANNGG!!! that looks GOOD! :shock:
Waiting for a report on how it sounds :D :D
From the looks, should be sometime soon :P :P
PostPosted: Mon Nov 10, 2008 11:30 pm
We still need some parts but getting closer. Mocked up the panel to see what that would look like. What do you think of the panel design?
PostPosted: Tue Nov 11, 2008 12:54 am
Fack that looks awesome! I want one!!!
Love the front panel.
How do you decide where the x-formers go with headphones btw?
PostPosted: Tue Nov 11, 2008 6:59 am
I like the front panel :P
First thing that struck me was the layout of the three inputs on one end and the power, standby and light on the other really reinforces the Triwatt name / theme (if that makes any sense to anybody :roll: )
How are the bright vol, normal vol, overdrive and master vol interactive?
PostPosted: Tue Nov 11, 2008 8:04 am
From AX84 FAQ
What is the headphone trick?
This is the best way to find the quietest place to put a reverb, output, driver, or any other signal transformer to get the least hum. CAUTION: THIS INVOLVES WORKING ON THE AMP WITH WALL VOLTAGE PRESENT. WALL VOLTAGE CAN BE FATAL.
First set up the power transformer. If it's not installed yet, all the better, but if it is, this will still help. If the PT is not installed, wire up the primaries to a power cord, but do not wire up any secondaries-- tape the ends of the secondaries. If the PT is installed, fine, just make sure there is no circuit on any of the secondary leads (pull all tubes, and disconnect leads and tape them as necessary).
Now set up the signal transformer (output, reverb, whatever). Hook one set of OT secondaries (your choice, but I usually go from ground to the highest impedance tap, don't worry about impedance matching here!) to a set of headphones. Tape the primary leads.
Put the headphones on, plug in the power cord, and start moving the signal transformer around. Try it all over the chassis, and also rotate it. While you might expect the least hum with the transformers as far from each other as possible and at right angles (and that may be the case for you), it might come at an odd angle and/or position. Sometimes the least hum occurs when the transformers are side by side. When you find the quietest spot, use a permanent marker to mark where the mounting holes should be.
If you have more than one signal transformer, repeat this for each one. When you're finished, unplug the PT. That's it!
PostPosted: Tue Nov 11, 2008 8:07 am
...and being that this is a Triwatt, I know that Stephen will make me proud with the cable harnesses :P
Wanna borrow my lacing cord :kool: 8)
