It is currently Sun Dec 14, 2025 12:29 am
Post new topic Reply to topic  [ 110 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sun Apr 12, 2009 9:27 am
Emohawk wrote:
First, I will say that I don't like the Triwatt with Vintage 30's. I said that for the V30 clips Brent recorded also. Having played through them myself I hold to that statement. I don't like them with other Brit amps either. They're just too top-end edgy for my tastes.
You're not alone in that. I don't like V30s with many amps due to their scooped tone and excessive top edginess, and I come across lots of other folks who feel the same way. I think they're OK for metal, or with amps that use EL34s, since EL34s generally tend to have warm strong mids. EL84s and V30s IMO are the worst combinations, since EL84s also tend to be somewhat bright, and the combination can get real ice-picky.
PostPosted: Sun Apr 12, 2009 10:55 am
Yeah - that seems to be the issue. Any amp that's naturally bright doesn't get along with them to my ears. They get on well with my Laney & my 2204, but it's too much for my Traynor, sIII, VJ or the Triwatt.
PostPosted: Sun Apr 12, 2009 1:10 pm
Just a quick update.
I've been playing with the lead dress trying to get rid of the squeal in the OD pot & some hum issues. I've moved all the coax so it now runs over the board instead of under. That helped quite a bit. I've noodled around with the positioning of the OD coax to V2 pin 2. The key seems to be the relationship of that wire to the wire running from the channel volumes to the OD switch.
I've got the squeal virtually eliminated. There is still a very faint squeal as extreme settings, but it's entirely gone in the usable range.
I'll keep noodling with it, and I'll be interested to see how AJC has run his wiring to eliminate it altogether.
PostPosted: Sun Apr 12, 2009 1:26 pm
my ears must be broken then.. I love C V30's with my 18 watter and TC15!
I often gig with my Orange closed back 4x12, and TC15. I also love my 2x12 with the G12H30's.
I have to use my new open back Trinity 2x12 with two TT alnico's to see how it rates.
AJC
PostPosted: Sun Apr 12, 2009 1:28 pm
it may be Monday, or even Tuesday untill I can get it apart and a pic taken.
AJC
PostPosted: Sun Apr 12, 2009 2:00 pm
Is there a metal botton plate (cover plate) for Stephens chassis? That makes a big diff. for hum and such things.
Stew
PostPosted: Sun Apr 12, 2009 2:15 pm
Stew
Not until you put it in a cab. Then you can use Aluminum tape or whatever if you want. But I think aj's was pretty quiet.
In the protoype, they went under the board. I just looked at the prototye pics and co-ax from the vol and OD switch went under the board, and came out between V2 - V3. Also, the shield of the co-ax lead from the OD switch that went to the board , was connected to the board ground buss as in the layout - in case you missed that.
Assume you grounded the output transformer common wire at the speaker jack sleeve terminal.
PostPosted: Sun Apr 12, 2009 4:37 pm
Stew
I didnt sheild mine and it is very very quiet now. Even with the od maxed out.
AJC
PostPosted: Sun Apr 12, 2009 5:23 pm
AJC
Ah - but not all cabinets are created equal! As I've discussed with Brent, Orange seems to have some sort of magic going on with their cabinets. I like the TT & a v30 loaded Orange cabinet. I've even heard a couple of G12T-75 loaded Orange cabs that sounded good, and I detest those speakers usually.
PostPosted: Sun Apr 12, 2009 5:25 pm
AJC
No rush dude. I've got mine to a point that I'm pretty happy with it so no big.
PostPosted: Sun Apr 12, 2009 5:33 pm
Stew
I always do that. Still playing around with it so I haven't mounted it in the cab yet.
The difference is probably due to the different orientation of the wires. I decided to try it over the board just to see if it mattered. I did notice the grounds to the bus. Those are fine.
I did indeed.
PostPosted: Sun Apr 12, 2009 7:23 pm
No more squeal! :D A bit more wire wiggling & it's completely gone now. Man - that lead from the channel volumes to the OD pot is extremely sensitive.
PostPosted: Sun Apr 12, 2009 9:33 pm
Yes, I bet if you got close enough and yelled at it, the wire would pick up your voice :)
Just like rubbing a stylus on a record player!
AJC
PostPosted: Sun Apr 12, 2009 9:57 pm
Is the lead you're referring to running from the volume pots to the OD pot the purple one on the layout?
Trying to figure out what I should be looking out for when my kit gets here :D
Thanks :!:
PostPosted: Sun Apr 12, 2009 10:18 pm
Yeah - that's the one. Just moving your hand near it causes interesting things to happen. I think it's probably a major source of noise & hum with the OD engaged too. Something else I'll be experimenting with.
PostPosted: Sun Apr 12, 2009 11:23 pm
This is very good news. Now you can crank it up without fear!
That wire would be the one that goes from the APEX of the 470K resistors from each volume pot to the OD control. Maybe we need to shield that short run?
In the prototype, we flew a lead from the APEX, in mid-air, to the OD control. Shortest distance.
Please take some pictures where it the placement works for you guys and comments as to what doesn't work and we'll incorporate your findings into the manual.
PostPosted: Mon Apr 13, 2009 8:29 am
Hmmm... with my TC15 they're anything but "ice-picky" and in the speaker poll on here they were the overwhelming favourite... I don't think this generalization applies to the TC...
Brent Bodrug
Producer-Engineer/Songwriter
www.slyfichapel.com
PostPosted: Mon Apr 13, 2009 8:31 am
AJC
FWIW, I actually prefer my Mesa cab with V30's over my Orange cab with my TC-15...
Brent Bodrug
www.slyfichapel.com
PostPosted: Mon Apr 13, 2009 9:23 am
I think the TC-15 is a pretty unique amp. Plus I have hunch that your own set of Mezza V30s are the original Made in England ones that you can't get any more, and are moreover, well worn in. :)
PostPosted: Mon Apr 13, 2009 10:40 am
The only fear is going deaf! The thing is crazy loud with th OD wound out & channel volumes up there. Even with the master down around 9:00 it's really cookin'.
The wire from the "apex", yeah. I originally had it running across from the "apex" & then up to the OD pot. I moved it to UP from the apex then across & the squeal disappeared completely. By doing this the wire is now basically at right angles to all the other leads in the same vicinity, whereas before it was more parallel. I suspect that's the difference.
We must be on the same wavelength. I thought it might be a good idea to shield that wire too, especially since with all that gain it's a major (potential) source of noise as well. Now that I have it working well I'm almost afraid to mess with it too much! :)
