It is currently Thu Jun 04, 2026 4:36 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
PostPosted: Wed Jul 27, 2005 11:03 am
does anyone have some nice plans or know where I can find (purchase) some nice layout/blue print(ish) plans for combo and head cabinets?
I'm interested in building a combo amp first based on the sweet sounding TMB sIII. Probably with a single 8 ohm greenback.
Any links or ideas would be appreciated. I'm still in the data collection phase, part sourcing phase. Maybe if we get some good info dear Stephen can make a sticky for here :)
PostPosted: Wed Jul 27, 2005 5:13 pm
Hmmm I actually found some stuff on the 18 Watt page...
http://www.18watt.com/modules.php?name=Downloads&d_op=viewdownload&cid=35
PostPosted: Wed Aug 10, 2005 6:11 am
I can post plans for cabs if you have found some good ones that work. I have various sets of plans for cabs I build, but I posted only the Lightning ones.
PostPosted: Thu Nov 10, 2005 12:31 am
The 18 Watt site has the combo plan, anyone have or located plans for the Head design
PostPosted: Thu Nov 10, 2005 9:29 am
I'll post some 'marked up' pics for you to use.
Meantime, if you want a small box head to fit the sIII, it's 24" X 8" x8" . You can even make it 22" wide if you want. Cut outs, front & rear - 16-1/2" X 2.25"
PostPosted: Thu Nov 10, 2005 6:10 pm
Here's the sIII head cabinet design, as a guideline and in rough format.
 Post subject: sIII chassis size
PostPosted: Mon Nov 28, 2005 2:22 am
The head cabinet images are great help, thanks.
Just for the record what are the dimensions of the sIII head chassis WxDxH.
I am still waiting for mine to arrive, but I am about to start building the box and want to be sure of the sizing. I will be using 3/4" ply for the outer sides.
Cheers
PostPosted: Mon Nov 28, 2005 2:18 pm
Rowbo:
Chassis Dimesnsions are: 20" W X 6.5" D X 2.5" H
or approx 510 X 165 X 65 +- 1 mm
PostPosted: Tue Nov 29, 2005 6:07 pm
Thanks Stephen,
Just confirming the depth measurement of 6 5/8" on the image, is the distance between the back of the Front panel and the back of the Back panel.
Therefore the 6 5/8" depth includes 6 1/2" for the chassis plus 1/8" to allow for the front and back face plates.
Cheers Rob.
PostPosted: Tue Nov 29, 2005 7:43 pm
rowbo wrote:
Thanks Stephen,
Cheers Rob.
Yes, the dimension is correct, 6-5/8" between the two panels.
PostPosted: Sun Dec 11, 2005 1:10 pm
Stephen,
I don't know if it's listed on the above diagram...but what thickness plywood is apropriate for the head cabinet?
also, what roundover bit is used for the cabinet and where?
-F
PostPosted: Sun Dec 11, 2005 2:06 pm
It's missing:
:arrow: 1/2" thick Baltic Birch plywood.
:arrow: 3/8" Radius roundover.
:idea: I use a Roman Ogee on the front edges to give it a bit more of a radius look.
PostPosted: Sun Dec 11, 2005 2:18 pm
It's missing:
Half inch? Thats it? hmm...
I've been using 3/4 on all my other various head cabs...I guess that makes sense, it looks a bit less 'thick'...
As far as the roundover goes....from what I can see from pictures of the 18watt head cabinets, the back corners of the cabinet are *not* rounded over, but the front and sides are....correct?
-F
PostPosted: Sun Dec 11, 2005 10:31 pm
Correct. Dont round over the rear. I use 3/4" on Matchless style cabs.
PostPosted: Sun Dec 11, 2005 11:11 pm
Right, I used 3/4" on mine as well...and the other amp...
But it makes sense that the marshall cab calls for a thinner ply....since it looks thinner in the pictures...
-F
PostPosted: Wed Jan 04, 2006 4:58 pm
Hey Stephen (or others),
I'm about to start rounding over my head cab....and I was wondering....do the openings on the front and back panels get rounded over with the 3/8" roundover as well?
-F
PostPosted: Wed Jan 04, 2006 5:16 pm
I round them over with 3/8" radius on the 18s; square on the 15s
PostPosted: Sun Jan 08, 2006 2:59 pm
Well, I've had good luck with wood stock in the past. However, the wood I used to build my sIII cabinet is a little suspect...either that, or I had the variable transformer for my router set too low.
I ended up with alot of tearing when I rounded over the head cabinet...so I've had to make some repairs with the aid of wood filler...
Good thing I'm covering this thing with tolex! :)
-Frank
PostPosted: Sun Jan 08, 2006 3:46 pm
It's really hard to not chip especially the finger joints in the corners. A little filler here & there is expected. Tolex will take care of any flaws!
PostPosted: Sun Jan 08, 2006 3:54 pm
Yeah, especially since we're working with ply, which I supose, would chip more than hardwood. Regardless, the cab is already filled and drying...nothing some sandpaper can't fix now...
Regardless, the 3/8" roundover looks good. I had run out and gotten myself a bit, since all I had here was a 1/2". Even though the difference is 1/8", the 1/2" bit would have looked stupid here....probably wouldn't have even worked with the 1/2" ply.
