joeypazz wrote:
I am in the process of building a Spitfire- it is coming along really slowly, but that's okay. I was just wondering what speakers you guys have been using for these amps. I have a Red Fang that I think I am going to be using for it, just wondering if you guys have any comments. The Spitfire I am building is going to be a little different, I have to use a SS rectifier, cause my xfmr has no centre tap. I am using both and OP and Power xfmr from a Trace Elliot Vellocette. I will probably have to use some Zeners to drop the voltage after the rectifier, but that should be no big deal. You will probably see me lurking around this forum more and more, as I get things moving along.
Joey;
Whats the Secondary Voltage on the PT? I use a SS Recto on my Thunderbolt 9 Spitfire/18 Watt Hybrid Amps.
CR ><>
