It is currently Sat Apr 19, 2025 7:49 am
PostPosted: Thu Jan 20, 2011 3:23 pm
Everyone,
Noobe to the site and new owner a 18 watt plexi kit. I just finished it up and it sounds great. I even installed a tube buffered effects loop and a solid state rectifier along with the EZ81. (switchable). I was wondering if anyone has any ideas to mod the tmb gain channel for more of an 80's rock tone.
PostPosted: Thu Jan 20, 2011 3:36 pm
There's some notes along with the schematic to "Fatten" up the tone and to "increase the gain" . That what you're after?
PostPosted: Thu Jan 20, 2011 3:58 pm
How do you like the solid state rectifier compared to the EZ81?
PostPosted: Thu Jan 20, 2011 4:45 pm
It is a little tighter and less compression. Good for more harder edge rock tones.
PostPosted: Thu Jan 20, 2011 4:46 pm
So pretty significant difference. Are you using full wave or half wave? Same filter caps as the tube when on solid state mode?
I am going to play around with those mods this weekend. I was wondering if there is a hot rodded JCM type of mod?
PostPosted: Thu Jan 20, 2011 4:55 pm
You can always cascade the normal channel into the TMB channel. With a toggle switch.
PostPosted: Thu Jan 20, 2011 4:57 pm
You have the Plexi version. you must want the TMB version for more gain. Take a look at the resource section. You can mod the TMB channel into the "TMB" model channel.
Confused yet?
PostPosted: Thu Jan 20, 2011 5:58 pm
Yes, this rules :happydance:
PostPosted: Thu Jan 20, 2011 8:16 pm
Isn't cascading the channels the same as using a patch cable to jumper the channels? I am not dead set on changing the TMB channel just yet. I will try the suggested gain mods and go from there. Or leave the amp alone as it sounds great as it is. :lol:
PostPosted: Thu Jan 20, 2011 11:07 pm
No, cascading is when you feed the output of one preamp channel into the input of the other preamp channel, so that the gain multiplies.
PostPosted: Fri Jan 21, 2011 8:49 am
The 3 18 watt models we have are the sIII, Plexi, TMB - Lo to Hi gain.
If you really have the Plexi and want more gain, go to the TMB design (see resource section for schematics / layout) and mod your Plexi to suit.
PostPosted: Fri Jan 21, 2011 10:06 am
Looking at my schematic. The plexi voiced channel is the normal channel and the TMB channel is called the sIII. I am confused now. My understanding from the posts is the TMB on my kit is the plexi circuit. My next question is If I do the changes on the TMB / Plexi channel on my amp to match the circuit of the TMB amp do I have to change my normal channel as well or leave it as is. I like that channel a lot.
PostPosted: Fri Jan 21, 2011 2:09 pm
They are separate channels. You do the mods in the pre-amp circuit.
And do the single switch cascade mod 8) from the normal channel you like to the TMB channel. I would do this first, I think you may be pleasantly surprized. Plexi to plexi is very cool IMO.
Tele's make the best noise
PostPosted: Fri Jan 21, 2011 7:22 pm
Anyone have a schematic for the cascade mod? :)
PostPosted: Fri Jan 21, 2011 8:13 pm
viewtopic.php?f=7&t=1798
Scroll down to the schematic. Instead of Cascade relays( :damntech: :evil: ) R2A and R2B, you will be installing a DPDT switch that way. Read the thread for more info.
PostPosted: Fri Jan 21, 2011 9:33 pm
Taz13 wrote:
http://www.trinityamps.com/phpbb/viewtopic.php?f=7&t=1798
Thanks Taz!
PostPosted: Fri Jan 21, 2011 10:31 pm
In the Plexi TMB channel, there are differnt coupling capacitors and Phase invertor drive is increased. It is based off the sIII but it's NOT an sIII TMB channel.
PostPosted: Wed Mar 16, 2011 1:06 am
bpkuder wrote:
Everyone,
bpkuder, I was wondering how your mods were going? Any success yet? Also I wanted to know how you implemented you SS rectifier. Did you just put a half wave recto in there? Any additional filtering or dropping resistors?
I was having issues with mine so I have just not used it but now I want to try to get it working.
Les
PostPosted: Wed Mar 16, 2011 1:19 am
Be aware that the amp will sound less brown with SS rectfiers. Also, the B+ voltage will go too high unless you also stick some zeners after the SS rectifiers to knock some volts off.
