Yes, I love the sound of vintage G12Hs too. The Eminence Wizard is very similar to a modern G12H-30, but slightly louder. A pair of those or a Wizard with Red Fang in a 2X12 will make you sound quite a bit louder. Use a closed back for tighter bass and better cut through. BBQ and Tone Tubby speakers are expensive to get shipped over to the UK.
If you need much more volume than that, then you basically need to upgrade your amp to 36W spec. That involves a bigger pair of transformers, and either adding an additional pair of EL84s, or else changing the EL84s for a pair of EL34s.
_________________ Great tones come in small glass jars!
