It is currently Sun Dec 14, 2025 12:11 am
PostPosted: Fri Apr 29, 2005 9:20 pm
Well, I just came back from a show where my 2X10 Lightning was featured by the lead guitarist. The band was awesome! The tunes from Country to Rock to Bluegrass!
The band members had never heard the amp, and they all commented how great it sounded. One time, the two guitarist were playing a Tele & Broadcaster. The Broadcaster was through the lightning. the tele through a Deluxe reverb. Completely different sound. Lightining was crisp and clear; Deluxe was flat and dull.
Anyhow, the player on the Lighting commmented that he really liked it but there were times he wanted it "Cleaner". I already am using a DC-30 OT, and will also change the impedence to reflect 8K instead of the 4K 'mismatch.
Any other ideas to clean it up a wee bit??
 Post subject: An idea
PostPosted: Sat Apr 30, 2005 9:21 pm
How about eliminating the parallel triodes in the first stage?
In other words just running one triode like a Spitfire.
It might be worth a try, if your friend likes squeaky clean country tone.
P.
PostPosted: Sat Apr 30, 2005 9:25 pm
Thanks, It might be worth a try if the impedance changes, and maybe a cathode bias decrease dont help.
PostPosted: Sat Apr 30, 2005 10:04 pm
A parallel triode offers about 20% more gain than a single triode, so you can ditch that and just use half of V1 for starters. You can also change the cathode resistor for the first stage and the cathode follower. Increasing those resistors has almost no impact on frequency response when you are using a 22uF bypass capacitor, so try something crazy like 4.7K on one or both of the cathodes.
Of course, changing the rectifier to a 5U4 will also help clean things up a bit.
I've never actually heard of someone wanting a cleaner Lightning. To each his own, I guess.
--s2
www.s2amps.com
www.category5amps.com
PostPosted: Sun May 01, 2005 12:07 am
LOL. It sounded great to me and he really liked it too. There were just some times when he wanted it to be louder / cleaner so I'll see what I can do to accommodate him.
I'll try the various suggestions. Starting with the impedance match. I like the idea of the cathode follower. Top Hat does that on their Club Deluxe [and maybe others].
PostPosted: Wed Sep 07, 2005 7:44 pm
Bits & Volts & I are looking for some more clean tweak ideas for the Lightning. Does anyone have any additional thoughts or experiences to share with us??
PostPosted: Wed Sep 07, 2005 7:50 pm
Here's a stupid question....what about dropping the plate resistor on V1 a hair?
or will that much with the effectiveness of the tone stack?
PostPosted: Wed Sep 07, 2005 8:13 pm
Maybe check out a Spitfire design. Some say the Spitfire has more clean headroom than a Lightning.
PostPosted: Wed Sep 07, 2005 8:27 pm
Stephen;
It does and a 2K2 Cathode Resistor on V1 adds more.
CR ><>
WoodCross Amps
PostPosted: Wed Sep 07, 2005 8:29 pm
You could try a 5751 in V1.
PostPosted: Wed Sep 07, 2005 8:42 pm
An NOS GE 5751 works Great in V1. Kinda like that Verboden Amp. HEHEHE.
CR ><>
WoodCross Amps
PostPosted: Wed Sep 07, 2005 8:44 pm
Does it affect the souind in any other way? Less volume perhaps? Alternate tone or just transparently cleaner?
PostPosted: Wed Sep 07, 2005 8:50 pm
The 5751 seems like a great non-invasive mod...
-F
PostPosted: Wed Sep 07, 2005 9:21 pm
If you've got one try it out & let me know how it sounds. I'm interested as well. I was looking for such an easy fix.
PostPosted: Wed Sep 07, 2005 9:27 pm
And dropping that plate resistor to 100K will help too.
--s2
www.s2amps.com
PostPosted: Wed Sep 07, 2005 9:45 pm
Just a bit cleaner. Doesn't loose that Chime at all.
CR ><>
WoodCross Amps
PostPosted: Wed Sep 07, 2005 10:29 pm
Cool, lots of good ideas here BV. Thanks guys. I'm gonna try some of these out for sure! Now, if I could just get that loaner amp back so I can play with it ...
PostPosted: Sat Sep 10, 2005 8:13 pm
I would suggest two more output tubes... :)
PostPosted: Sat Sep 10, 2005 8:27 pm
That might break the rules of the game, somewhat...
PostPosted: Sun Sep 11, 2005 6:20 pm
Also, what about the odds of just making the distortion louder without adding headroom? A common "complaint" about the 5E3X2 design by Ted BBQ & friends.
