It is currently Sat Jan 31, 2026 6:25 am
 Post subject: Cascade mod
PostPosted: Sat Oct 15, 2011 2:05 pm
Hi, Following kurtlives schematic posted in a new TC is born, I've drawn up where I think I can get connections on the layout.
Not quite sure if i should take the B+ where I have...Any thoughts?
 Post subject: Re: Cascade mod
PostPosted: Sat Oct 15, 2011 2:40 pm
Take the B+ from the filter cap on the far right (the one with the 220K plate resistor on it).
I'll check switching when I get a minute.
PostPosted: Sat Oct 15, 2011 3:05 pm
Like this.....
The 22nf cap, 680K, R1 & R2 seem to be in circuit at all times. Do these have any effect on the parallel mode?
PostPosted: Sat Oct 15, 2011 4:57 pm
Switch wiring is not correct. Check pin 1 against my schem. (you might need to add an extra eyelet)
It's close but it looks like you mixed up some of the switch contacts. Notice which ones are common and which are the throws.
PostPosted: Sat Oct 15, 2011 5:16 pm
Also, in the sketch, aren't the 680k/R1/R2 combo serving as basically a static gain dump? These become redundant when you include the gain pot, if I'm seeing this correctly......with the 680K across pins 1 and 3 of the 1M pot, you're effectively converting it to ~400k pot & changing the curve a bit. This isn't necessarily a bad thing, but if you're looking for the frequency response & curve of a 1M pot, I don't think this will get you there. Here's what I came up with for one of my amps.......very much based on your original diagram. Many thanks for posting it. My amp is much different than the TC-15 so the resistor & cap values don't apply here.....but the topography is very similar.
** b0b0 **
- This Space For Rent -
PostPosted: Sun Oct 16, 2011 10:07 am
Sorry, I've missed the B+ supply to pin 6 when in cascade mode. Not sure where I need an extra eyelet.I've moved the B+ supply from pin 1 to pin 6. Bobo, I had a quick look at your schematic. Thanks for posting it. Looks very similar to what I'm trying to get. What about the 500k gain pot in parallel mode, does it lose any gain because of it?
PostPosted: Sun Oct 16, 2011 1:37 pm
Did you use the extra eyelet for the 25uf cap/1K resistor?
PostPosted: Mon Oct 17, 2011 3:41 pm
Your close!
- Cathode switching is correct
- Grid switching is not correct (look at where the you have pins 2 and 7 mixed up essentially, study the schem)
- Plate switching is not correct, you got some of the lugs mixed up
PostPosted: Mon Oct 17, 2011 7:34 pm
Ok the parts I need to wire to mod arrived today. I think better with parts and a soldering iron than I do with a piece of paper :damntech: I'll post tomorrow and see if I have it sorted!
PostPosted: Tue Oct 18, 2011 5:31 pm
Right, here's what I've done. It works perfectly! 8) I didn' use an extra eyelet (would've been handy if I had one!) Changed Gain pot to 500k. A1M overloads the amp! fitted pot on front of amp with a black knob, looks angry! Massive amount of distortion available but can also do clean if the gain is dropped off. Different sound to parallel clean, less warmth but quite useful. Distortion gets a very convincing whole lotta love type sound right up to ACDC.
Wont get to crank it properly till tomorrow...... next REVERB!!!
PostPosted: Tue Oct 18, 2011 5:35 pm
Here's a shot of the extra pot. Thanks to kurtlives and Bobo for all your help. I couldn't have done it without you :D
PostPosted: Tue Oct 18, 2011 6:03 pm
Very cool!
If you use a 1M pot and include the 680K resistor you will have no problems, o well!
There is lots you can do to adjust the tone of the cascade mode if you want.
PostPosted: Tue Oct 18, 2011 6:13 pm
Thanks, I was thinking of dropping the value of the 25uF cap on the cathode to 8 or maybe even 4, its got a bit too much bass. What about a switch to select different caps..... Ah fun and games!
PostPosted: Tue Oct 18, 2011 6:58 pm
Is there too much bass or not enough highs?
Try making the 2.2nF cap 1nF.
As a test put another 2.2nF cap in parallel with the one already there. See if you like that.
Does the gain pot do anything when in parallel mode? Please check
PostPosted: Tue Oct 18, 2011 7:23 pm
Thanks for sharing this one. Very cool!
PostPosted: Fri Oct 21, 2011 9:19 pm
It does seem to be too much bass when the gain is up high, I had the bass set right down and the treble about 3/4 full and still thought there was too much bass! I'll try changing the 2.2nF first. Moving the gain pot has no effect in
parallel mode. Clean tone still sounds the same to me. I was expecting some slight drop in volume due to the pot, but nothing noticeable.
PostPosted: Sat Oct 22, 2011 10:12 am
The pot should do nothing out of the circuit, parallel clean mode should sound the same as stock.
Change that 2.2nF cap to 1nF and see how that works.
PostPosted: Mon Oct 24, 2011 8:18 pm
[quote="kurtlives"]Is there too much bass or not enough highs?
Correct me if I'm wrong but I thought 2 x 2.2nF in parallel gives 4.4nF? Opposite to resistance.
Series : 1/CTotal = 1/C1 + 1/C2 + ....
Parallel: CTotal = C1 + C2 + ....
Anyway, I changed the 2.2nF for a 1nF. It definitely improved the tone, more sparkle. But I still found I was
setting the basscontrol very low all the time. Changed the 25uF for an 8uF Sprague Atom.
Now I tend to have the bass set about half way, control is much better.
PostPosted: Mon Oct 24, 2011 8:19 pm
Opps sorry your right. :shock: Brain is going nuts these days!
PostPosted: Thu Nov 03, 2011 9:19 am
Just one last addition, I had to add a 1M resistor in series with the 500K pot to stabilise the gain.
